How Hard To Remove This ?, Windshield-Dash Cosmetic Strip |
Ansbacher |
Apr 6 2020, 01:56 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
How hard is it to remove the interior cosmetic strip at the junction of the dash and windshield? Mine is starting to crack apart from age and I want to replace with a 914Rubber replacement. Does the windshield have to come out? Will removing the strip compromise the windshield seal? Input appreciated.
Ansbacher |
Mikey914 |
Apr 6 2020, 10:17 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes it can actually rust to the metal lip (one of the reasons I made mine the way I did). If it does it's a pain to remove. I just takes more time.
So when you install mine, cut the contour of the pillar into one side and do the same on the other intending to make it 1/4" longer than you need. You can then try to install both ends in 1st then push down to the center. You can trim it a little at a time. When it installs the pressure will cause it to hyper extend and will stay in place. Enjoy! |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:22 AM |
