simonjb |
KiwiMan ![]() ![]() ![]() Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States ![]() ![]() |
So I decided to clean up my original engine while I run the car with a modified scat engine.
When I drained the oil I found these....two small pieces and the nut.....(dime for size). So I started to tear down the top end and found one cylinder that looked not so good. The others are the same as the right side. went down further and removed the pistons and am now cleaning them all up. Everything looks ok. I really don’t want to split the case or go any further and from what I see inside all look good. So two questions.... 1) any thought on why this cylinder isn’t firing right ? 2) can I use something like gasoline or similar to flush and clean out the inside of the case with the crank and oil pump etc still attached? 3) any reason why I can’t use all the old parts ? 4) any thought on the nut? Thanks.... ![]() ![]() ![]() |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
^^ All good points.
I'd add the Wilson book as a good resource as well: https://www.amazon.com/Rebuild-Volkswagen-a...s/dp/0895862255 Try to develop a plan before you start buying parts. Completely stock, induction system, what compression ratio, etc. These are things I eventually figured out as I went along, but an experienced builder goes into a rebuild knowing them ahead of time. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
^^ All good points. I'd add the Wilson book as a good resource as well: https://www.amazon.com/Rebuild-Volkswagen-a...s/dp/0895862255 Try to develop a plan before you start buying parts. Completely stock, induction system, what compression ratio, etc. These are things I eventually figured out as I went along, but an experienced builder goes into a rebuild knowing them ahead of time. (IMG:style_emoticons/default/agree.gif) I don't know how I forgot that one! That book is a must have. That book actually is what I learned with before there was ever an internet or Raby videos! I still have my original, and it's falling to pieces. This past Christmas my wife bought me a new copy! (IMG:style_emoticons/default/santa_smiley.gif) Best wife ever! |
Lo-Fi Version | Time is now: 10th June 2024 - 10:35 AM |
