> Need /4 oil pump and pressure line advice, Need to plumb oil to turbo--how??
Mueller
post May 22 2003, 07:25 PM
914 Freak!
I am rebuilding my motor for a turbocharger.
The motor will be using the stock cam so my RPM redline will remain the same as that on a stock normally asperiated motor.
1) Should I replace the stock oil pump?
2) If so, with which one?
3) Will non-stock pump need to be modified?
I need a constant oil flow for the bearings of the turbo.
4) What are my options for getting this oil?
5) Can I plumb into the oil pump?
6) Is there a place on the block I can tap into for the oil?
Thanks,
Mike
Brad Roberts
post May 22 2003, 07:44 PM
914 Freak!
www.all914.com
projects
jason samson
Melling high volume pump O ringed.. engine case match ported to pump.
High pressure kit for the oil gallies.
Come off the hole for the oil pressure sending unit (tee off of it).. and the most important..
Return the oil to the side of a tuna can....
B
Mueller   Need /4 oil pump and pressure line advice   May 22 2003, 07:25 PM
Brad Roberts   www.all914.com projects jason samson Melling hi...   May 22 2003, 07:44 PM
bernbomb914   Brad could yourun a external oil cooler the same w...   May 22 2003, 07:54 PM
Mark Henry   I don't care to much for the s-melling pump (i...   May 22 2003, 08:37 PM
seanery   Mueller, I saw on web-cam's page that they ha...   May 22 2003, 08:45 PM
Brad Roberts   The only reason I say Melling... they are asy to g...   May 22 2003, 09:22 PM
airsix   <...   May 22 2003, 09:24 PM
Brad Roberts   I agree (easily) The valve cover idea is stupid s...   May 22 2003, 09:27 PM
Aaron Cox   what if you dumped it into one of those deep sump ...   May 22 2003, 09:29 PM
bernbomb914   are those deep sump thingabobbies worthwhile? I ge...   May 22 2003, 09:56 PM
Mockmaw   It's my understanding that deep sumps should o...   May 22 2003, 10:12 PM
Mueller   Looking at those pictures of Jasons motor, it look...   May 22 2003, 11:33 PM
Mark Henry
- Lo-Fi Version Time is now: 24th October 2026 - 08:34 PM
