lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Undertook a pedal cluster rebuild on the 912 this morning, and that friggin' roll pin has defeated me. I've tried a pin punch, then heat, then drilling the sucker out. Haven't moved the pin one bit and I've now broken four drill bits (two inside the pin).
Thing is, this car is my daily driver, so I need it running on Monday. I *can* just put the floppy cluster back in, but I really rather not. I can also steal the rebuilt cluster out of my barely running 914 (temporarily). However, if there's anyone in the Bay Area with a press or an EDM or some other tool that stands a better chance of getting this pin out, I'd love to pay you a visit. |
mikey |
Member ![]() ![]() Group: Members Posts: 425 Joined: 30-January 03 From: San Francisco Member No.: 214 Region Association: None ![]() |
I went through this same thing a couple of months ago following the article on the Bird Board.
I broke drill bits, used a mapp torch (hotter than propane), and whacked on it with a big hammer. The pin never moved. What finally worked was getting the pedal cluster oriented and held securely so that it could be squarely hit with a drift and hammer. That took two people. I held it and Luis at HPH smacked it once or twice REALLY hard and the pin broke loose. Due to the shape of the cluster it couldn't be held in a vice tightly enough to hold it while hitting it with a hammer. Pushing the pin out with a vise didn't work. However, a vice worked well reinstalling the new pin. Be sure to use the spiral pin as a replacement *and* the bronze bushings instead of the plastic ones. Also, IIRC the re-assembly instructions on PP were slightly out of sequence. Do a dry run before finally greasing up the bushings. |
Lo-Fi Version | Time is now: 12th July 2025 - 04:02 PM |
