| Mueller |
May 22 2003, 07:25 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,157 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I am rebuilding my motor for a turbocharger.
The motor will be using the stock cam so my RPM redline will remain the same as that on a stock normally asperiated motor. 1) Should I replace the stock oil pump? 2) If so, with which one? 3) Will non-stock pump need to be modified? I need a constant oil flow for the bearings of the turbo. 4) What are my options for getting this oil? 5) Can I plumb into the oil pump? 6) Is there a place on the block I can tap into for the oil? Thanks, Mike |
| Aaron Cox |
May 22 2003, 09:29 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
what if you dumped it into one of those deep sump thingy boppers? gives you more room for the "frothed" oil
Mueller Need /4 oil pump and pressure line advice May 22 2003, 07:25 PM
Brad Roberts www.all914.com
projects
jason samson
Melling hi... May 22 2003, 07:44 PM
bernbomb914 Brad could yourun a external oil cooler the same w... May 22 2003, 07:54 PM
Mark Henry I don't care to much for the s-melling pump (i... May 22 2003, 08:37 PM
seanery Mueller,
I saw on web-cam's page that they ha... May 22 2003, 08:45 PM
Brad Roberts The only reason I say Melling... they are asy to g... May 22 2003, 09:22 PM
airsix <... May 22 2003, 09:24 PM
Brad Roberts I agree (easily)
The valve cover idea is stupid s... May 22 2003, 09:27 PM
bernbomb914 are those deep sump thingabobbies worthwhile? I ge... May 22 2003, 09:56 PM
Mockmaw It's my understanding that deep sumps should o... May 22 2003, 10:12 PM
Mueller Looking at those pictures of Jasons motor, it look... May 22 2003, 11:33 PM
Mark Henry ![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 08:34 PM |
