> 914 flywheel vs a bus flywheel, any differences?
malcolm2
post Apr 26 2020, 07:43 AM
I sure can’t see any.
Building a 2.0 from a 1.8 from a 914 for my 72 bus that came with a 1.7. Have both flywheels. I did not label either. The 914 was running when removed so it must be the shinier one. The bus sat in a field for 10 years. So much moisture under there that the magnesium bell housing deteriorated.
Anyway, both are 210 mm. Some vendors say their 914 FW won’t work on a bus and visa-versa.
Anyone have more details?
Attached Image Attached ImageAttached Image
Mark Henry
post Apr 26 2020, 09:42 AM
that's what I do!
Bus came with a 210, 215 and the 228mm.
I know for sure the bus flywheels have a small pilot hole.
malcolm2
post Apr 26 2020, 10:57 AM
QUOTE(Mark Henry @ Apr 26 2020, 10:42 AM) *
OK. I removed the pilot bearing of the above pictured FW and got the same diameter as the rusty on in the pic. I am pretty sure the bus engine had been out at some point.... 1. they painted the tins and valve covers. 2. looks like this rusty flywheel was re-installed without the thin 5 hole washer and the serrated bolts dug in. So maybe the PO put a 914 FW in with no FW pilot bearing or spacer.
Am I right about the years and the sizes of the FW? I did read where folks could not fit a 228 in a 72 bell housing.
- Lo-Fi Version Time is now: 2nd April 2026 - 11:09 AM
