> Need /4 oil pump and pressure line advice, Need to plumb oil to turbo--how??
Mueller
post May 22 2003, 07:25 PM
914 Freak!
I am rebuilding my motor for a turbocharger.
The motor will be using the stock cam so my RPM redline will remain the same as that on a stock normally asperiated motor.
1) Should I replace the stock oil pump?
2) If so, with which one?
3) Will non-stock pump need to be modified?
I need a constant oil flow for the bearings of the turbo.
4) What are my options for getting this oil?
5) Can I plumb into the oil pump?
6) Is there a place on the block I can tap into for the oil?
Thanks,
Mike
Mockmaw
post May 22 2003, 10:12 PM
It's my understanding that deep sumps should only be used on track cars because of clearance issues if run on the street.
Mueller   Need /4 oil pump and pressure line advice   May 22 2003, 07:25 PM
Brad Roberts   www.all914.com projects jason samson Melling hi...   May 22 2003, 07:44 PM
bernbomb914   Brad could yourun a external oil cooler the same w...   May 22 2003, 07:54 PM
Mark Henry   I don't care to much for the s-melling pump (i...   May 22 2003, 08:37 PM
seanery   Mueller, I saw on web-cam's page that they ha...   May 22 2003, 08:45 PM
Brad Roberts   The only reason I say Melling... they are asy to g...   May 22 2003, 09:22 PM
airsix   <...   May 22 2003, 09:24 PM
Brad Roberts   I agree (easily) The valve cover idea is stupid s...   May 22 2003, 09:27 PM
Aaron Cox   what if you dumped it into one of those deep sump ...   May 22 2003, 09:29 PM
bernbomb914   are those deep sump thingabobbies worthwhile? I ge...   May 22 2003, 09:56 PM
Mockmaw   It's my understanding that deep sumps should o...   May 22 2003, 10:12 PM
Mueller   Looking at those pictures of Jasons motor, it look...   May 22 2003, 11:33 PM
Mark Henry
- Lo-Fi Version Time is now: 24th October 2026 - 08:33 PM
