| tygaboy |
May 6 2020, 04:00 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,805 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
Hi V8 folks -
I'm looking for recommendations to size my torsion bars and rear spring rates. Component-wise, it's an LS3 with Boxster 6-speed. The total drive train weight is around 575 lbs. I'm running Koni yellows (helper springs on the rear), 17mm raised front spindles and the 2" Tangerine rear suspension points and tall shock tower kit. I'd like the ride to be sporty but tolerable. if that means anything! The use case is "spirited street driving" I'm not worried about ultimate track performance - at least not yet. So, wha'cha running? Thanks, Chris Attached thumbnail(s) |
| Chris914n6 |
May 6 2020, 08:55 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,530 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Stock 911 front and 180-200lbs in back.
tygaboy V8 conversions: Torsion bar size and rear spring rates? May 6 2020, 04:00 PM
ValcoOscar This is my LS Car with 901. Boxster S trans is st... May 6 2020, 04:10 PM
MidshipMadness
This is my LS Car with 901. Boxster S trans is s... May 7 2020, 09:08 AM
tygaboy @ValcoOscar - Looks great! But what rate rear... May 6 2020, 04:30 PM
FL 000 Chris,
I don't have a baseline for comparison... May 6 2020, 05:20 PM
roblav1 On my performance based build, I have 21mm Sway Aw... May 6 2020, 06:15 PM
tygaboy
On my performance based build, I have 21mm Sway A... May 6 2020, 06:38 PM
roblav1 Ahhh! Helper springs. I have the yellow Koni ... May 6 2020, 08:24 PM
Andyrew Your running a big bar up front.
You also have g... May 7 2020, 01:59 AM
tygaboy @ValcoOscar @FL 000 [b]@[url=http://www.914world... May 7 2020, 07:35 AM
Krieger I don't know what size springs you have now, b... May 7 2020, 08:14 AM
tygaboy
I don't know what size springs you have now, ... May 7 2020, 08:32 AM
Krieger I had the same problem as you. You can ditch the ... May 7 2020, 08:27 AM
andys Stock '89 Carrera 18.8 front T bars, and 200# ... May 7 2020, 09:01 AM
dan10101 Hey Chris,
A little late to the game.
I'm at... May 10 2020, 05:06 PM
tygaboy
Hey Chris,
I'm a... May 10 2020, 06:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 05:55 AM |
