| tygaboy |
May 6 2020, 04:00 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,805 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
Hi V8 folks -
I'm looking for recommendations to size my torsion bars and rear spring rates. Component-wise, it's an LS3 with Boxster 6-speed. The total drive train weight is around 575 lbs. I'm running Koni yellows (helper springs on the rear), 17mm raised front spindles and the 2" Tangerine rear suspension points and tall shock tower kit. I'd like the ride to be sporty but tolerable. if that means anything! The use case is "spirited street driving" I'm not worried about ultimate track performance - at least not yet. So, wha'cha running? Thanks, Chris Attached thumbnail(s) |
| ValcoOscar |
May 6 2020, 04:10 PM
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,607 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California
This is my LS Car with 901. Boxster S trans is stored for now. Ride is very tolerable, not uncomfortable at all. No twisties yet. (IMG:style_emoticons/default/headbang.gif)
190 lb Springs...Let me check torsion bars. Oscar |
| MidshipMadness |
May 7 2020, 09:08 AM
Newbie ![]() Group: Members Posts: 27 Joined: 28-March 20 From: Hudson, WI Member No.: 24,064 Region Association: None |
This is my LS Car with 901. Boxster S trans is stored for now. Ride is very tolerable, not uncomfortable at all. No twisties yet. (IMG:style_emoticons/default/headbang.gif) 190 lb Springs...Let me check torsion bars. Oscar How is the 901 holding up to the torque? I didn't have any luck with a 915. |
tygaboy V8 conversions: Torsion bar size and rear spring rates? May 6 2020, 04:00 PM
tygaboy @ValcoOscar - Looks great! But what rate rear... May 6 2020, 04:30 PM
FL 000 Chris,
I don't have a baseline for comparison... May 6 2020, 05:20 PM
roblav1 On my performance based build, I have 21mm Sway Aw... May 6 2020, 06:15 PM
tygaboy
On my performance based build, I have 21mm Sway A... May 6 2020, 06:38 PM
roblav1 Ahhh! Helper springs. I have the yellow Koni ... May 6 2020, 08:24 PM
Chris914n6 Stock 911 front and 180-200lbs in back. May 6 2020, 08:55 PM
Andyrew Your running a big bar up front.
You also have g... May 7 2020, 01:59 AM
tygaboy @ValcoOscar @FL 000 [b]@[url=http://www.914world... May 7 2020, 07:35 AM
Krieger I don't know what size springs you have now, b... May 7 2020, 08:14 AM
tygaboy
I don't know what size springs you have now, ... May 7 2020, 08:32 AM
Krieger I had the same problem as you. You can ditch the ... May 7 2020, 08:27 AM
andys Stock '89 Carrera 18.8 front T bars, and 200# ... May 7 2020, 09:01 AM
dan10101 Hey Chris,
A little late to the game.
I'm at... May 10 2020, 05:06 PM
tygaboy
Hey Chris,
I'm a... May 10 2020, 06:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 06:00 AM |
