| Joe C |
May 9 2020, 01:14 PM
Newbie ![]() Group: Members Posts: 14 Joined: 3-January 19 From: New York Member No.: 22,773 Region Association: North East States |
Recently replaced plugs, points, cap, rotor, wires, coil. Car was running great for about 150 miles then started to sputter like it was running out gas. Luckily made it to a gas station filled up and went on my way..... for about two miles and it just died!
This is a 1970 six with 45k miles. Its getting fuel, Points are good and correctly adjusted, CD box whistles when the key is on but there is no spark at the coil. Checked all the grounds and had my head in the engine compartment for hours looking for loose or broken wires. Any ideas????? And by the way, if you have classic car insurance make sure you opt in for the towing. I didn't, $175.00 for the hook up and a 6 mile trip!!! |
| porschetub |
May 9 2020, 06:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,081 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Tony and John are dead on with replies,the bosch 3 pin can buzz but still have issues , these units are so old now and prone to failing,when researching my system I went for the "blue" (75 911 MY ) Permatune which is known to be very reliable,however they require a matching permatune transformer coil which is rather spendy ,I was lucky to find a NOS unit for sensible money on Ebay.
Ashlocktech offer a rebuild service for the Bosch CDI's which compared to risking buying secondhand is a good option @ $279 with your core , good price really. Pretty sure you need to match the coil to the CDI you have also. Good luck. |
Joe C 1970 914/6 May 9 2020, 01:14 PM
Retroracer Couple of suggestions:
1) check the polarity of t... May 9 2020, 01:48 PM
Joe C Thanks Tony,
Already tried the old coil and no lu... May 9 2020, 03:42 PM
johnlush Joe,
BTDT. In my case it was a bad ground to the ... May 9 2020, 04:04 PM
dakotaewing
Recently replaced plugs, points, cap, rotor, wire... May 9 2020, 06:38 PM
IronHillRestorations Make sure the CD box is plugged in good, and has a... May 10 2020, 07:46 AM
Superhawk996
One thing I've learned is about half of igni... May 10 2020, 08:30 AM
Superhawk996
One thing I've learned is about half of igni... May 10 2020, 08:31 AM
Joe C
Make sure the CD box is plugged in good, and has ... May 10 2020, 06:55 PM
porschetub
Make sure the CD box is plugged in good, and has ... May 10 2020, 11:36 PM
Make sure the CD box is plugged in good, and has... May 11 2020, 05:33 AM
rgalla9146 ^ :agree: with Perry
Check for gas fro... May 10 2020, 08:32 AM
porschetub
Check for gas fr... May 10 2020, 09:17 PM
Joe C
Check for gas f... May 11 2020, 12:27 PM
rgalla9146
[quote name='porschetub' post='2813841' date='May... May 11 2020, 03:25 PM
ClayPerrine
Actually it's far easier and certainly more ... May 12 2020, 07:33 AM
IronHillRestorations Check the distributor cap and make sure it's s... May 11 2020, 05:35 AM
ClayPerrine This may help you..
http://www.914world.com/bbs2/... May 11 2020, 07:18 AM
johnhora Also I've found the early CDI boxes don't ... May 11 2020, 07:49 AM
ClayPerrine
Also I've found the early CDI boxes don't... May 11 2020, 07:52 AM
johnlush Yep! :agree: May 11 2020, 04:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 06:55 PM |
