| tornik550 |
May 9 2020, 06:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have seen a lot of posts regarding brake feel however my setup is a bit different than the articles I have seen. My car is mainly used for spirited street driving and occasional auto-x. Here is my current setup (all components are close to new):
-“wide-A” 911 front calipers -vented front and rear rotors -“vintage brakes” 914/6GT rear calipers -19mm master cylinder -ss brake lines -adjustable proportioning valve I realize my brakes are overkill for my needs. I have bled the brakes many times. My main question is- would a different master cylinder be of benefit? If so- larger or smaller? |
| mepstein |
May 10 2020, 07:53 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,522 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Also replace your ss soft lines if they are old. They will swell internally. Standard rubber lines are fine.
tornik550 How to improve brake feel May 9 2020, 06:03 PM
DickSteinkamp What is it about the present "feel" that... May 9 2020, 06:37 PM
mepstein Larger MC = harder brake pedal, less pedal travel ... May 9 2020, 06:43 PM
tornik550 I don’t really like how the pedal is somewhat so... May 9 2020, 06:50 PM
tornik550 What exactly does the lever type proportioning val... May 9 2020, 06:57 PM
roblav1 A lot of brake feel has to do with the pads too. May 9 2020, 07:06 PM
tornik550 Also- forgot to mention that I have porterfield r4... May 9 2020, 08:13 PM
yeahmag Have you set the rear venting clearance correctly?... May 10 2020, 01:11 AM
914Sixer Put the brake regulator back on and ditch the valv... May 10 2020, 06:06 AM
roblav1 1) 19mm master cylinder is right, as already state... May 10 2020, 07:41 AM
GregAmy Do these rear braskes require manual adjustment? I... May 10 2020, 07:59 AM
roblav1
Do these rear braskes require manual adjustment? ... May 10 2020, 08:04 AM
GregAmy
Did you race with NER SCCA? If so, I probably kn... May 10 2020, 08:09 AM
roblav1 When you see Fred again, tell him for me to dump t... May 10 2020, 08:20 AM
sixnotfour Check floor board flex..see tanegerine racings bra... May 10 2020, 12:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 12:27 AM |
