| tygaboy |
May 6 2020, 04:00 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,805 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
Hi V8 folks -
I'm looking for recommendations to size my torsion bars and rear spring rates. Component-wise, it's an LS3 with Boxster 6-speed. The total drive train weight is around 575 lbs. I'm running Koni yellows (helper springs on the rear), 17mm raised front spindles and the 2" Tangerine rear suspension points and tall shock tower kit. I'd like the ride to be sporty but tolerable. if that means anything! The use case is "spirited street driving" I'm not worried about ultimate track performance - at least not yet. So, wha'cha running? Thanks, Chris Attached thumbnail(s) |
| dan10101 |
May 10 2020, 05:06 PM
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Hey Chris,
A little late to the game. I'm at 22 and 250# I'm 2550# if that makes a difference. Tolerable ride with good handling. |
| tygaboy |
May 10 2020, 06:23 PM
Hey Chris, A little late to the game. I'm at 22 and 250# I'm 2550# if that makes a difference. Tolerable ride with good handling. @dan10101 Dan - No worries, thanks for the input. With the 930 box, your car is a good match for mine, weight-wise. I'm going to start with 21 and 225 and adjust as needed. Thanks again! |
tygaboy V8 conversions: Torsion bar size and rear spring rates? May 6 2020, 04:00 PM
ValcoOscar This is my LS Car with 901. Boxster S trans is st... May 6 2020, 04:10 PM
MidshipMadness
This is my LS Car with 901. Boxster S trans is s... May 7 2020, 09:08 AM
tygaboy @ValcoOscar - Looks great! But what rate rear... May 6 2020, 04:30 PM
FL 000 Chris,
I don't have a baseline for comparison... May 6 2020, 05:20 PM
roblav1 On my performance based build, I have 21mm Sway Aw... May 6 2020, 06:15 PM
tygaboy
On my performance based build, I have 21mm Sway A... May 6 2020, 06:38 PM
roblav1 Ahhh! Helper springs. I have the yellow Koni ... May 6 2020, 08:24 PM
Chris914n6 Stock 911 front and 180-200lbs in back. May 6 2020, 08:55 PM
Andyrew Your running a big bar up front.
You also have g... May 7 2020, 01:59 AM
tygaboy @ValcoOscar @FL 000 [b]@[url=http://www.914world... May 7 2020, 07:35 AM
Krieger I don't know what size springs you have now, b... May 7 2020, 08:14 AM
tygaboy
I don't know what size springs you have now, ... May 7 2020, 08:32 AM
Krieger I had the same problem as you. You can ditch the ... May 7 2020, 08:27 AM
andys Stock '89 Carrera 18.8 front T bars, and 200# ... May 7 2020, 09:01 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 05:57 AM |
