> Floor pan, Replacement
Duane921
post May 10 2020, 04:11 AM
I am about to replace a floor pan in my 73 914. Can anyone recommend the best replacement parts for me? Thanks for any replies.
bkrantz
post May 10 2020, 08:36 PM
I will second what Brent (and others) wrote. Replacing the floor pan (in sections) is pretty straight forward, and easier on a lift or some way to turn the car sideways or upside down. A good spot weld cutting bit, and lots of fun time, will detach the jack point triangles and most of the floor seams (along the longitudinals on the sides and the inner fire wall). Where the floor joins the outer firewall (in the engine compartment) and the center tunnel there are both spot welds and seam welding).
But the real problem is finding the limit of rust. In addition to the floor, you need to inspect the longs, the inner and outer firewall, and the suspension mounting (especially right side). And don't forget where the floor meets the front bulkhead. Get a good light an a sharp ice pick and stab everything hard.
Duane921   Floor pan   May 10 2020, 04:11 AM
Duane921   RE: Floor pan   May 10 2020, 04:58 AM
BeatNavy   http://www.restoration-design.com/store/category/9...   May 10 2020, 05:14 AM
Duane921   Ive built supports for the door wells and all meas...   May 10 2020, 05:45 AM
911GT2   Ive built supports for the door wells and all mea...   May 10 2020, 06:50 AM
Superhawk996   I am about to replace a floor pan in my 73 914. C...   May 10 2020, 09:04 AM
Duane921   I am replacing the cross members and inner firewal...   May 10 2020, 04:09 PM
Superhawk996   Picture? If you talking about the portion betwe...   May 10 2020, 05:53 PM
Duane921   It looks like the floor pan fits above this bracke...   May 10 2020, 06:30 PM
Duane921   I am not sure how to get the old floor pan out and...   May 10 2020, 06:36 PM
bbrock   That bracket gets taken off as part of the floor r...   May 10 2020, 07:56 PM
bkrantz   I will second what Brent (and others) wrote. Repl...   May 10 2020, 08:36 PM
Duane921   Love the advice. Ill add the jack plates to my lis...   May 11 2020, 03:13 AM
jaredmcginness   I had an enjoyable time doing my floors. Stock the...   May 11 2020, 05:11 AM
bbrock   I'll pass along another bit of great advice I ...   May 11 2020, 07:46 AM
Duane921   I leveled everything and found measurements from R...   May 11 2020, 09:59 AM
Duane921   Brent, if you have any tips or tricks to make sure...   May 11 2020, 11:11 AM
bbrock   I'll let others answer that since lots of peop...   May 11 2020, 11:53 AM
Duane921   Parts are due in this week. Is there a best sequen...   May 17 2020, 05:45 AM
- Lo-Fi Version Time is now: 1st May 2026 - 04:46 AM
