Cavity Foam? |
Cavity Foam? |
bkrantz |
May 10 2020, 09:13 PM
914 Guru Group: Members Posts: 7,804 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I have removed all the rigid foam from inside the rear trunk lid trailing edge rib, in order to repair rust. I would like to replace the foam since it adds rigidity and connects the rib (which hosts the trunk latch mount) to the outer skin. Any recommendations on materials and process?
IronHillRestorations |
May 12 2020, 09:45 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I wonder about treating it all with Eastwood's cavity spray really thoroughly and then using the foam. One consideration is that your 914 will probably never see the exposure it got, pre restoration.
That said, trapping moisture is always a concern. |
Lo-Fi Version | Time is now: 10th June 2024 - 04:25 AM |
