LED Headlight weirdness, Please help |
VaccaRabite |
May 13 2020, 07:28 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Over the winter I installed a set of LED headlights from Vintage Car LED.
I just took m first drive with them and there is some strange goings on. 1) I turned on the lights, start driving down the road and they blinked on and off for a second. Couple miles later they did it again. And then again as I got closer to home on a bumpy section of road. 2) none of the dash lamps on my gauge cluster light up any more. 3) my Piloti driving lights will not turn on either. A glance at my fuse panel did not show any glowing fuses, but I did not pull them out to inspect so that could be an issue. Turn signals and break lights work fine. My guess is that something is going on with the headlight switch. Opinions? Other things to check? Zach |
eric9144 |
May 14 2020, 08:39 AM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Interesting, I have all LED's on the /6 and when I was driving the other day early in the morning, I noticed it "bouncing" back and forth between low/fog and hi/no-fog, then it seemed to settle down. Think I'll be grounding out the blue/white wire also (IMG:style_emoticons/default/beerchug.gif)
Going to make a ground wire with a spade connector so I can just "plug and play" the fix vs cutting anything. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:21 PM |
