Beater 2316, Deck height vs. CR |
groot |
May 2 2020, 01:15 PM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
So, finally getting around to building a "beater" engine to develop my race car project (been idle too long). The idea is to build a reliable, decent engine that's not crazy expensive to sort out my car, then put in the expensive engine when the chassis is ready. I will only use race fuel with this engine.
Basic specs are:
Now, the question... should I source 0.220" or larger shims to drop the CR at the expense of deck height? A shim of 0.220" will drop the CR to 10.4:1, but raises the deck height to 0.050" Thoughts? |
groot |
May 14 2020, 11:35 AM
So, I've taken steps to seal the case, entirely... dry sumps should be sealed case, but I've never seen a type 4 with a sealed case... I know my scavenge stage is not big enough to generate much vacuum, but, I'm going to hook up a MAP sensor to see if it does anything... and, I'll have to watch the valve cover gaskets.
I run an external pressure regulator, so no need for any case pressure regulation/relief. I found a nifty adapter that allows this setup: |
Lo-Fi Version | Time is now: 13th June 2024 - 11:48 PM |
