> Slightly fast idle - suspect AAV, Am I right?
gturner008
post May 14 2020, 06:29 AM
Owned 76 2.0 for two weeks now.
Lots of little jobs completed. But I have an idle that’s 1100 rpm. The idle screw is virtually fully in.
I suspect the AAV is stuck slightly open when engine hot. If I pull the tube from the air intake and put my thumb over it, the revs drop to about 600 rpm.
Everything else is good. All hoses correct and no leaks.
Am I right in thinking the AAV should close up completely?
If it’s a stuck AAV, any recommendations for getting it freed up?
Cheers. Gary
gturner008
post May 14 2020, 12:33 PM
Update.
Removed AAV or ARR, cleaned. Put 12v through it.
Got it to close right up. Reinstalled. Ran car to hot. Valve closed off completely as pulled pipe and thumb over. No drop in revs.
Car now idles at 1000 rpm, with idle screw fully in.
I’m thinking I now need to check timing. Can’t think of anything else.
Again, great advice. Now sorted the AAV.
- Lo-Fi Version Time is now: 28th September 2026 - 10:40 AM
