> flywheel groove, fix, leave or trash
malcolm2
post May 13 2020, 12:15 PM
I know I have read about this somewhere. Flywheel has a couple grooves. The top one can be felt with my fingernail. So what do you folks think?
Superhawk996
post May 14 2020, 03:50 PM
There's always a po' man's shortcut. 914's are famous for it. (IMG:style_emoticons/default/happy11.gif)
Usually a flywheel that is that worn on the sealing surface has other wear issues on the clutch surface.
I've been broker' than broke. I understand. I really do. But, penny wise pound foolish is also a lesson I've learned from the school of hard knocks! (IMG:style_emoticons/default/stirthepot.gif)
It seems to me that three new failure modes have been added.
1) Eventual weepage between the sleeve and the flywheel. Tech sheet says: Pressure seal up to 50 psi: Suitable
for higher-pressure sealing applications; typical industrial shaft seals can handle only up to 5 or 10 psi. Should be OK. Won't have a gusher but I think weepage would still be a risk.
2) The added diameter of the sleeve will pre-load the RMS lip more and may accelerate the seal wear.
3) Position of the seal and the sleeve need to be set properly at install to allow for crank end play and the final at rest postion of the RMS such that the sleeve is always under the seal.
SKF is a decent company and probably has some testing behind these but I suspect they are intended for industrial maintenance scenarios where keeping equipment up and running is sometimes the critical task while proper replacement parts are ordered and then scheduled maintenance is done at a convenient time.
Any follow up on how this holds up over time would be cool! Always willing to learn if there is a better way.
malcolm2   flywheel groove   May 13 2020, 12:15 PM
Mblizzard   Well as long as they are not super deep I say poli...   May 13 2020, 12:31 PM
malcolm2   speedi sleeve ?? anyone ever use something like ...   May 13 2020, 12:46 PM
Superhawk996   Replace. You'll thank me later.   May 13 2020, 12:55 PM
cuddy_k   :agree: New ones aren't crazy expensive...and ...   May 13 2020, 12:59 PM
IronHillRestorations   If you can feel it catch on a fingernail, it's...   May 13 2020, 01:30 PM
malcolm2   Not mine, but here is the Autozone sleeve... Mine...   May 13 2020, 05:34 PM
Superhawk996   There's always a po' man's shortcut. ...   May 14 2020, 03:50 PM
malcolm2   No update on the sleeve. I will report here if I ...   May 19 2020, 03:33 PM
Superhawk996   You're not going to like my response. If yo...   May 19 2020, 04:26 PM
malcolm2   You're not going to like my response. If y...   May 19 2020, 05:26 PM
Superhawk996   You're not going to like my response. If ...   May 19 2020, 06:05 PM
malcolm2   No offense taken. I agree. Any loss with a small ...   May 19 2020, 08:02 PM
Bleyseng   I think it's the 210 for the 1.7L, 215mm for t...   May 19 2020, 10:59 PM
Mark Henry   You can offset the seal depth, but you can see thi...   May 20 2020, 06:40 AM
Superhawk996   @Mark Henry Nice link. Thank you for sharing. ...   May 20 2020, 11:14 AM
Mark Henry   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 20 2020, 11:57 AM
MartyYeoman   speedi sleeve ?? anyone ever use something like...   May 20 2020, 12:41 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:57 PM
