| Jim C |
May 18 2020, 08:24 AM
Member ![]() ![]() Group: Members Posts: 206 Joined: 11-July 19 From: Pennsylvania Member No.: 23,294 Region Association: MidAtlantic Region
Want to see what the World thinks of this. I have a 1976 2.0 with FI. Injectors have been cleaned and checked, ECU repaired, CO checked, trigger points replaced, valves adjusted, timing set, but at idle it goes from barely running to 1000 RPM or so in a rhythmic manner. Also, when accelerating you can feel a momentary drop in power. Thoughts? (IMG:style_emoticons/default/confused24.gif)
| Jim C |
May 18 2020, 09:02 AM
Want to see what the World thinks of this. I have a 1976 2.0 with FI. Injectors have been cleaned and checked, ECU repaired, CO checked, trigger points replaced, valves adjusted, timing set, but at idle it goes from barely running to 1000 RPM or so in a rhythmic manner. Also, when accelerating you can feel a momentary drop in power. Thoughts? (IMG:style_emoticons/default/confused24.gif) Any prime suspects for the leak? |
Jim C Pulsing At Idle May 18 2020, 08:24 AM
76-914 Vacuum leak. May 18 2020, 08:47 AM
dr914@autoatlanta.com I second that
Vacuum leak.
May 18 2020, 08:58 AM
BeatNavy
[quote name='Jim C' post='2816424' date='May 18 2... May 18 2020, 10:30 AM
JamesM
I would have said something is making you run lea... Jun 4 2020, 12:07 PM
alexkirkham
I would have said something is making you run le... Jun 4 2020, 01:26 PM
dr914@autoatlanta.com that is an excellent thing that you did
[quote n... Jun 4 2020, 01:54 PM
Jim C
Want to see what the World thinks of this. I hav... May 18 2020, 10:35 AM
Literati914 Isn't there anything you can run thru the engi... May 18 2020, 10:46 AM
StarBear
Isn't there anything you can run thru the eng... Jun 4 2020, 09:57 AM
JeffBowlsby
Isn't there anything you can run thru the eng... Jun 4 2020, 01:24 PM
Bleyseng I spray starting fluid in small amounts May 18 2020, 10:51 AM
saigon71
Want to see what the World thinks of this. I have... May 18 2020, 03:52 PM
Jim C I checked the vacuum hoses and replaced those that... Jun 4 2020, 08:41 AM
Jim C
I checked the vacuum hoses and replaced those tha... Jun 4 2020, 08:42 AM
Bleyseng Put a few drops of oil in the center shaft of the ... Jun 4 2020, 08:58 AM
rjames Have you tried adjusting the knob on your ECU? Try... Jun 4 2020, 09:45 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:03 AM |
