| SKL1 |
May 18 2020, 08:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,831 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
Surprised there is no good picture in the factory workshop manual to show position of the flaps in the closed or open positions.
In this picture it is in the fail-safe position as if the cable or thermostat wasn't working. Just want to make sure they are correct. When hooking up the thermostat wire the flaps would both move as the little "lever" would move down. Just seems strange that in the fail-safe mode it covers up the oil cooler- you 'd think it would want air going over and through the cooler to allow the engine to run cooler if the thermostat failed... |
| cary |
May 18 2020, 08:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
SKL1 Proper position of "cooling" flaps May 18 2020, 08:50 PM
bbrock It's actually not covering up the oil cooler. ... May 18 2020, 08:54 PM
SirAndy Just seems strange that in the fail-safe mode it c... May 18 2020, 09:13 PM
SKL1 Thanks! I knew I had seen those somewhere bef... May 18 2020, 09:14 PM
jim_hoyland How do you set the end of the wire in the clamp? E... May 18 2020, 09:32 PM
cuddy_k
How do you set the end of the wire in the clamp? ... May 18 2020, 09:43 PM
flipb
How do you set the end of the wire in the clamp? ... May 19 2020, 05:33 AM
falcor75 Wire should be tight when the engine is cold since... May 18 2020, 09:44 PM
Olympic 914
Wire should be tight when the engine is cold sinc... May 19 2020, 07:08 AM
mtndawg http://www.914world.com/bbs2/index.php?sho...=9243... May 18 2020, 11:33 PM
barefoot This might help as well:
May 19 2020, 04:54 AM
Craigers17
That's a very h... May 19 2020, 06:05 AM
BeatNavy I find the easiest way is to carefully put a heat ... May 19 2020, 06:04 AM
porschetub
I find the easiest way is to carefully put a heat... May 19 2020, 02:48 PM
BeatNavy
Hot tip,replace the cable with a bike cable they ... May 19 2020, 02:58 PM
andrewvolsen Edit: posted to wrong thread, sorry Nov 15 2026, 10:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th November 2026 - 02:50 PM |
