> flywheel groove, fix, leave or trash
malcolm2
post May 13 2020, 12:15 PM
I know I have read about this somewhere. Flywheel has a couple grooves. The top one can be felt with my fingernail. So what do you folks think?
malcolm2
post May 19 2020, 03:33 PM
No update on the sleeve. I will report here if I run across any news.
If I may, let's go to the other side of the FW. As I mentioned this is a TIV in a bus. The bus FW came in several friction surface diameters. The diameters got larger over the years. 200 then 210, 215 by late 73, then 228 for the Vanagon Aircooled.
Looks like the PO had a 215 mm FW and a 210 pressure plate and disk. Anyone see a benefit to doing that? Am I losing torque or power with that set up?
My FW is 215, should I get the 215 clutch?
malcolm2   flywheel groove   May 13 2020, 12:15 PM
Mblizzard   Well as long as they are not super deep I say poli...   May 13 2020, 12:31 PM
malcolm2   speedi sleeve ?? anyone ever use something like ...   May 13 2020, 12:46 PM
Superhawk996   Replace. You'll thank me later.   May 13 2020, 12:55 PM
cuddy_k   :agree: New ones aren't crazy expensive...and ...   May 13 2020, 12:59 PM
IronHillRestorations   If you can feel it catch on a fingernail, it's...   May 13 2020, 01:30 PM
malcolm2   Not mine, but here is the Autozone sleeve... Mine...   May 13 2020, 05:34 PM
Superhawk996   There's always a po' man's shortcut. ...   May 14 2020, 03:50 PM
malcolm2   No update on the sleeve. I will report here if I ...   May 19 2020, 03:33 PM
Superhawk996   You're not going to like my response. If yo...   May 19 2020, 04:26 PM
malcolm2   You're not going to like my response. If y...   May 19 2020, 05:26 PM
Superhawk996   You're not going to like my response. If ...   May 19 2020, 06:05 PM
malcolm2   No offense taken. I agree. Any loss with a small ...   May 19 2020, 08:02 PM
Bleyseng   I think it's the 210 for the 1.7L, 215mm for t...   May 19 2020, 10:59 PM
Mark Henry   You can offset the seal depth, but you can see thi...   May 20 2020, 06:40 AM
Superhawk996   @Mark Henry Nice link. Thank you for sharing. ...   May 20 2020, 11:14 AM
Mark Henry   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 20 2020, 11:57 AM
MartyYeoman   speedi sleeve ?? anyone ever use something like...   May 20 2020, 12:41 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:12 PM
