| malcolm2 |
May 13 2020, 12:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
I know I have read about this somewhere. Flywheel has a couple grooves. The top one can be felt with my fingernail. So what do you folks think?
| Superhawk996 |
May 19 2020, 04:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
You're not going to like my response.
If your racing and have upped HP, have a V8 conversion, or something else, that will dictate different parts. You're overthinking it. Put factory parts in it. Be done with it. It was an engineered system and works just fine when used as intended with stock or near stock motors. |
| malcolm2 |
May 19 2020, 05:26 PM
You're not going to like my response. If your racing and have upped HP, have a V8 conversion, or something else, that will dictate different parts. You're overthinking it. Put factory parts in it. Be done with it. It was an engineered system and works just fine when used as intended with stock or near stock motors. They all are OEM parts. Someone just mixed them up. Maybe on purpose by some slick shop that knew no one would call him on it. Or a PO that didn’t measure or had a “that will work” attitude. It is obvious that they work. Question is: am i losing anything? For some reason VW made it all, what 2.5% bigger in 73 or 74. Why? |
| Superhawk996 |
May 19 2020, 06:05 PM
You're not going to like my response. If your racing and have upped HP, have a V8 conversion, or something else, that will dictate different parts. You're overthinking it. Put factory parts in it. Be done with it. It was an engineered system and works just fine when used as intended with stock or near stock motors. They all are OEM parts. Someone just mixed them up. Maybe on purpose by some slick shop that knew no one would call him on it. Or a PO that didn’t measure or had a “that will work” attitude. It is obvious that they work. Question is: am i losing anything? For some reason VW made it all, what 2.5% bigger in 73 or 74. Why? Honestly I don't know. Perhaps someone can chime in with the 100% correct answer. As far as I know all 914's were 215 clutch and flywheel between all 1.7/1.8L/2.0L 4 cylinder engines. Actually the area difference between a 215 and 210 is going to be closer to an 8% area (assuming inner radius of annular area stays constant) loss since area is a function of radius squared. So the question is would you want to lose 8% of surface friction area by going to the 210mm clutch. I wouldn't. I'd stay with what the factory engineerd. Hope I'm not coming off as a jerk. That is not my intent. I'd just stay with an engineered system. |
malcolm2 flywheel groove May 13 2020, 12:15 PM
Mblizzard Well as long as they are not super deep I say poli... May 13 2020, 12:31 PM
malcolm2 speedi sleeve ??
anyone ever use something like ... May 13 2020, 12:46 PM
Superhawk996 Replace. You'll thank me later. May 13 2020, 12:55 PM
cuddy_k :agree: New ones aren't crazy expensive...and ... May 13 2020, 12:59 PM
IronHillRestorations If you can feel it catch on a fingernail, it's... May 13 2020, 01:30 PM
malcolm2 Not mine, but here is the Autozone sleeve...
Mine... May 13 2020, 05:34 PM
Superhawk996 There's always a po' man's shortcut. ... May 14 2020, 03:50 PM
malcolm2 No update on the sleeve. I will report here if I ... May 19 2020, 03:33 PM
malcolm2 No offense taken. I agree. Any loss with a small ... May 19 2020, 08:02 PM
Bleyseng I think it's the 210 for the 1.7L, 215mm for t... May 19 2020, 10:59 PM
Mark Henry You can offset the seal depth, but you can see thi... May 20 2020, 06:40 AM
Superhawk996 @Mark Henry
Nice link. Thank you for sharing.
... May 20 2020, 11:14 AM
Mark Henry
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 20 2020, 11:57 AM
MartyYeoman
speedi sleeve ??
anyone ever use something like... May 20 2020, 12:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:13 PM |
