| bkrantz |
May 21 2020, 08:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,783 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Move the pump (1973 2.0) from the stock location to the front? If so, cut an access hole like later years?
Can somebody please send a photo of the frunk rear wall, taken straight on, so I can get some dimensions for the hole? |
| Tbrown4x4 |
May 22 2020, 03:08 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 709 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None
I put a CB pump up front under the tank, with the filter mounted by the steering rack. DD like this for 3 years without problems. I do want to add the plate and hole to avoid pulling the tank if the pump fails. (You never know.)
I handled my pump wiring with a module from Revolution Electronics. https://www.revolutionelectronics.com/Produ.../Fuel_Pump.html I found it easier to wire the pump from the fuse panel, and I like the 3 second prime and the safety shut off. (No ign signal, no pump.) If the module fails, you short the purple wires together and drive home. |
bkrantz Another Fuel Pump Location Thread May 21 2020, 08:56 PM
stevegm I’m working on the same problem now too. I’m t... May 21 2020, 08:59 PM
ndfrigi several members have place it beside the steering ... May 21 2020, 09:26 PM
porschetub
several members have place it beside the steering... May 22 2020, 03:27 PM
yellowporky I did a lot of searching for photos too and this i... May 22 2020, 12:41 AM
mlindner Well, I moved my tank and pump, just FYI. Mark May 22 2020, 05:10 AM
roblav1 I ran stainless lines, appropriately bent, through... May 22 2020, 11:44 AM
bkrantz Thanks, everyone. May 22 2020, 09:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 04:44 AM |
