| KevinW |
May 22 2020, 11:43 AM
Newbie ![]() Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest
I am looking for a drawing or detail Or picture how to route the fuel lines. I have searched the web but no luck. I have an idea about the supply line but not sure about the return line?
Thanks |
| IronHillRestorations |
May 22 2020, 06:14 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,956 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
I'm with Chris on this. I've never run a return line on a carbureted engine. That's not to say that Brant isn't right, in that a return line system with a bypass regulator is probably theoretically the optimum.
There's two basic types of regulators; blocking and bypass. Where and how you use them is the important part. You can also get a bypass regulator that can be controlled with vacuum so you get the optimum pressure at all times. For a street 914 I've had great results with the correct fuel pump direct to the carbs. KISS |
KevinW Dual Weber 40’s May 22 2020, 11:43 AM
brant this has been a controversial topic for ever...
a ... May 22 2020, 01:29 PM
bbrock There is another reason to keep the return line. ... May 22 2020, 01:48 PM
Superhawk996
There is another reason to keep the return line. ... May 22 2020, 02:05 PM
bbrock
I'm wondering if those with the 1/8 tank scen... May 22 2020, 03:27 PM
Superhawk996
I'm wondering if those with the 1/8 tank sce... May 22 2020, 03:48 PM
bbrock
Now I'm super curious!
The contraption ... May 22 2020, 04:06 PM
SKL1 That makes sense but I've been running carbs o... May 22 2020, 02:06 PM
ChrisFoley I have never used a return line on a carbed car an... May 22 2020, 05:20 PM
KevinW I will be using a Facet fuel pump. When not using ... May 22 2020, 06:34 PM
ChrisFoley
I will be using a Facet fuel pump. When not using... May 23 2020, 09:58 AM
bbrock
You can also get a bypass regulator that can be c... May 22 2020, 06:47 PM
SirAndy Facet pumps will drive you batty with the noise. ... May 22 2020, 08:09 PM
mtndawg
Facet pumps will drive you batty with the noise. ... May 22 2020, 10:25 PM
ndfrigi
[quote name='bbrock' post='2818051' date='May 22... May 23 2020, 01:23 AM
mtndawg
[quote name='mtndawg' post='2818099' date='May 22... May 23 2020, 01:19 PM
ndfrigi
[quote name='mtndawg' post='2818099' date='May 2... May 23 2020, 02:10 PM
Ansbacher The inventor of the Facet type pump is now sitting... May 23 2020, 11:24 AM
IronHillRestorations I may have been talking through my hat. There use... May 23 2020, 12:13 PM
KevinW Thank you everyone for the advice May 23 2020, 04:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 06:13 AM |
