| KevinW |
May 22 2020, 11:43 AM
Newbie ![]() Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest
I am looking for a drawing or detail Or picture how to route the fuel lines. I have searched the web but no luck. I have an idea about the supply line but not sure about the return line?
Thanks |
| bbrock |
May 22 2020, 06:47 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
You can also get a bypass regulator that can be controlled with vacuum so you get the optimum pressure at all times. Can you explain a little more about this type? I'm shopping for a bypass regulator now and had pretty much settled on the PMO, but interested about the theory behind a vacuum controlled regulator and where to find them. I hadn't come across them and it's a part of the car I'd like to know more about. I will be using a Facet fuel pump. When not using a return line do you cap the return at the fuel tank? Facet pumps will drive you batty with the noise. I've used them. They work, but are about as fun as having a hairy nun drum her fingers on your skull for hours on end. Never again. |
| SirAndy |
May 22 2020, 08:09 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,521 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Facet pumps will drive you batty with the noise. I've used them. They work, but are about as fun as having a hairy nun drum her fingers on your skull for hours on end. Never again. (IMG:style_emoticons/default/agree.gif) Rotary pumps are the way to go ... |
| mtndawg |
May 22 2020, 10:25 PM
Member ![]() ![]() Group: Members Posts: 420 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None
Facet pumps will drive you batty with the noise. I've used them. They work, but are about as fun as having a hairy nun drum her fingers on your skull for hours on end. Never again. (IMG:style_emoticons/default/agree.gif) Rotary pumps are the way to go ... Yes I have a rotary pump and no return line and it runs great! Attached thumbnail(s) |
KevinW Dual Weber 40’s May 22 2020, 11:43 AM
brant this has been a controversial topic for ever...
a ... May 22 2020, 01:29 PM
bbrock There is another reason to keep the return line. ... May 22 2020, 01:48 PM
Superhawk996
There is another reason to keep the return line. ... May 22 2020, 02:05 PM
bbrock
I'm wondering if those with the 1/8 tank scen... May 22 2020, 03:27 PM
Superhawk996
I'm wondering if those with the 1/8 tank sce... May 22 2020, 03:48 PM
bbrock
Now I'm super curious!
The contraption ... May 22 2020, 04:06 PM
SKL1 That makes sense but I've been running carbs o... May 22 2020, 02:06 PM
ChrisFoley I have never used a return line on a carbed car an... May 22 2020, 05:20 PM
IronHillRestorations I'm with Chris on this. I've never run a ... May 22 2020, 06:14 PM
KevinW I will be using a Facet fuel pump. When not using ... May 22 2020, 06:34 PM
ChrisFoley
I will be using a Facet fuel pump. When not using... May 23 2020, 09:58 AM
ndfrigi
[quote name='bbrock' post='2818051' date='May 22... May 23 2020, 01:23 AM
mtndawg
[quote name='mtndawg' post='2818099' date='May 22... May 23 2020, 01:19 PM
ndfrigi
[quote name='mtndawg' post='2818099' date='May 2... May 23 2020, 02:10 PM
Ansbacher The inventor of the Facet type pump is now sitting... May 23 2020, 11:24 AM
IronHillRestorations I may have been talking through my hat. There use... May 23 2020, 12:13 PM
KevinW Thank you everyone for the advice May 23 2020, 04:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 06:13 AM |
