> Dual Weber 40’s, Fuel lines
KevinW
post May 22 2020, 11:43 AM
I am looking for a drawing or detail Or picture how to route the fuel lines. I have searched the web but no luck. I have an idea about the supply line but not sure about the return line?
Thanks
bbrock
post May 22 2020, 06:47 PM
QUOTE(IronHillRestorations @ May 22 2020, 06:14 PM) *
You can also get a bypass regulator that can be controlled with vacuum so you get the optimum pressure at all times.
Can you explain a little more about this type? I'm shopping for a bypass regulator now and had pretty much settled on the PMO, but interested about the theory behind a vacuum controlled regulator and where to find them. I hadn't come across them and it's a part of the car I'd like to know more about.
QUOTE(KevinW @ May 22 2020, 06:34 PM) *
I will be using a Facet fuel pump. When not using a return line do you cap the return at the fuel tank?
Facet pumps will drive you batty with the noise. I've used them. They work, but are about as fun as having a hairy nun drum her fingers on your skull for hours on end. Never again.
post May 22 2020, 08:09 PM
Resident German
QUOTE(bbrock @ May 22 2020, 05:47 PM) *
(IMG:style_emoticons/default/agree.gif) Rotary pumps are the way to go ...
mtndawg
post May 22 2020, 10:25 PM
QUOTE(SirAndy @ May 22 2020, 06:09 PM) *
Yes I have a rotary pump and no return line and it runs great!
ndfrigi
post May 23 2020, 01:23 AM
QUOTE(mtndawg @ May 22 2020, 09:25 PM) *
sorry Kevin to change topic! @mtndawg do u mind sharing what kind of catch can or breather do u have attached to rear wall and where is that white line goin?
thank you!
mtndawg
post May 23 2020, 01:19 PM
QUOTE(ndfrigi @ May 22 2020, 11:23 PM) *
thank you!
I think I found this on eBay or amazon. It’s aluminum, size is nice and black to match the tin. Venting out the rain tray tubing hole on the driver side. I’ve thought about going back into the engine through the air intake and making a manifold for the intake to clean things up a bit. It’s on my to do list.
ndfrigi
post May 23 2020, 02:10 PM
QUOTE(mtndawg @ May 23 2020, 12:19 PM) *
thank you!
so the line is just going down the floor.
thank you for sharing. Oh that is a clean engine bay!
KevinW   Dual Weber 40’s   May 22 2020, 11:43 AM
brant   this has been a controversial topic for ever... a ...   May 22 2020, 01:29 PM
bbrock   There is another reason to keep the return line. ...   May 22 2020, 01:48 PM
Superhawk996   There is another reason to keep the return line. ...   May 22 2020, 02:05 PM
bbrock   I'm wondering if those with the 1/8 tank scen...   May 22 2020, 03:27 PM
Superhawk996   I'm wondering if those with the 1/8 tank sce...   May 22 2020, 03:48 PM
bbrock   Now I'm super curious! The contraption ...   May 22 2020, 04:06 PM
SKL1   That makes sense but I've been running carbs o...   May 22 2020, 02:06 PM
ChrisFoley   I have never used a return line on a carbed car an...   May 22 2020, 05:20 PM
IronHillRestorations   I'm with Chris on this. I've never run a ...   May 22 2020, 06:14 PM
KevinW   I will be using a Facet fuel pump. When not using ...   May 22 2020, 06:34 PM
ChrisFoley   I will be using a Facet fuel pump. When not using...   May 23 2020, 09:58 AM
bbrock   You can also get a bypass regulator that can be c...   May 22 2020, 06:47 PM
SirAndy   Facet pumps will drive you batty with the noise. ...   May 22 2020, 08:09 PM
mtndawg   Facet pumps will drive you batty with the noise. ...   May 22 2020, 10:25 PM
ndfrigi   [quote name='bbrock' post='2818051' date='May 22...   May 23 2020, 01:23 AM
mtndawg   [quote name='mtndawg' post='2818099' date='May 22...   May 23 2020, 01:19 PM
ndfrigi   [quote name='mtndawg' post='2818099' date='May 2...   May 23 2020, 02:10 PM
Ansbacher   The inventor of the Facet type pump is now sitting...   May 23 2020, 11:24 AM
IronHillRestorations   I may have been talking through my hat. There use...   May 23 2020, 12:13 PM
KevinW   Thank you everyone for the advice   May 23 2020, 04:40 PM
- Lo-Fi Version Time is now: 24th September 2026 - 06:13 AM
