| North Coast Jim |
May 22 2020, 04:12 PM
Member ![]() ![]() Group: Members Posts: 348 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
Engine is out and I'm doing some investigations. Bought a set of Redline 40 IDFs for the engine build. They've run OK but not great. Couldn't keep lean idle set properly. drivability an issue, pops and backfires at times. Jetting changes made no difference. Suspected gasket air leaks. Should have done the starting fluid check but didn't.
While the engine is out took the manifolds off from the heads. The gasket as supplied from Redline is a thick phenolic (?) spacer with paper adhered to both sides. Found a defect in each one at both ports. Near the top of each port the phenolic has a defect - a void. The paper on each side covers the defect but does not seal the intake. Found evidence of a leak path at this area Question - do I need the phenolic spacers ?? Can't find them on line as single replacement parts. Read of a need to keep the carbs from heat soaking but the manifolds are aluminum and are 5" tall. Don't see a need for them. Am I correct in this analysis ?? Was thinking of using .060" gaskets with Permatex red (min film deposit ) at this interface instead. What wisdom can you all impart. Thanks for any and all input |
| GregAmy |
May 24 2020, 06:09 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,700 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
North Coast Jim Carb manifold sealing May 22 2020, 04:12 PM
MikeM Here's my 2 cents...
I had a terrible problem ... May 23 2020, 11:08 AM
Mark Henry Use them. May 23 2020, 11:20 AM
North Coast Jim
Use them.
Thanks Mark, always value your opinio... May 24 2020, 05:43 AM
Al Meredith I have had problems like yours, Found the manifold... May 23 2020, 11:31 AM
HAM Inc
I have had problems like yours, Found the manifol... May 24 2020, 07:59 AM
porschetub
I have had problems like yours, Found the manifo... May 24 2020, 03:50 PM
cpavlenko I had the same problem with percolation after a dr... May 23 2020, 11:37 AM
80cap I just had the same problem
I bought new gaskets f... May 24 2020, 06:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 04:52 AM |
