They do fail, Them ECU’s |
Porschef |
May 22 2020, 10:55 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
A couple weeks back I hit some real rough road on my way home from my mechanic neighbor’s shop. The car started running out of power, I made it another couple hundred feet before it died. With help from said neighbor we were able to push it down the road to a safe spot, where Hagerty towing picked it up.
I have a fuel pressure gauge in the engine bay, whenever I would engage the pump it would build up pressure and immediately fall to zero. I thought I had a bad injector or maybe the cold start valve failed, so I pulled them all individually and checked them; they were all leaking. A Noid light showed them all to be open. WTH? My neighbor suspected the ECU, but based on what I’ve read they rarely fail. Anyway everything else seemed ok so I put out a WTB and Jim Hoyland responded with a unit and an offer to check it out and then buy it if it worked . So last evening I pulled the harness off the one in the car and plugged it into the new one. Presto! Pressure held right where it should. A quick experiment putting the harness back into the old one got the same previous result. So I’m pretty confident that the problem has been resolved. As much as I wanted to start it, I did not based on the oil reeking of gas. So I’ll do a change, and see what happens. Big thanks to Jim for helping out, it’s a great community. (IMG:style_emoticons/default/beerchug.gif) |
Big Len |
May 24 2020, 04:09 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Get out there. Good job.
Lo-Fi Version | Time is now: 11th June 2024 - 02:17 AM |
