front shift rod diameter |
AZBanks |
May 29 2020, 09:28 AM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Are the front shift rods the same diameter for side and tail shift transmissions?
My car is a '71 that was converted to a side shift transmission. I bought the Rix conversion shift bushing from 914 rubber but I can not get it to stay on place when I push the front shift rod through the firewall. It pushes the bushing out. The shift rod diameter where it passes through the firewall is .92 inches, 23.39 mm. What bushing do I need for that size front shift rod? |
Mikey914 |
May 29 2020, 10:39 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The rix version we have is the early car upgrade to side shift bushing. It should be the same size as the one you have to drill into the wall (Personally don't like making that kind of modification).
Why don't I ship you out the other 2 bushings (early and late) just in case some "modifications" haven't been made by a previous owner. One of the should fit. Just drop me back what you don't need. PM me your address and I will do this right now. Mark |
Lo-Fi Version | Time is now: 12th June 2024 - 07:34 AM |
