Alternator light on? |
914Toy |
May 30 2020, 01:19 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
My alternator light comes on with ignition on, and stays on with engine running, and voltage stays at 12V regardless of rpm's. Was charging regularly at nearly 14V. The fan belt is in good order at spec tension. The alternator was reconditioned a couple of years ago and now has about 5,000 miles on it. The diode behind the gauge was also replaced, but I have had the gauge in and out a few times working on other issues - possibly damaging it(?)
Before removing the alternator for testing, could the diode behind the gauge be faulty preventing charging? If so, what is the spec of these diodes? Your suggestions will be welcome. |
dr914@autoatlanta.com |
May 30 2020, 02:12 PM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
pull the regulator and make sure that the light goes out. If it does plug in a new voltage regulator (probably not that) so if the belt is tight the alternator has a problem
My alternator light comes on with ignition on, and stays on with engine running, and voltage stays at 12V regardless of rpm's. Was charging regularly at nearly 14V. The fan belt is in good order at spec tension. The alternator was reconditioned a couple of years ago and now has about 5,000 miles on it. The diode behind the gauge was also replaced, but I have had the gauge in and out a few times working on other issues - possibly damaging it(?) Before removing the alternator for testing, could the diode behind the gauge be faulty preventing charging? If so, what is the spec of these diodes? Your suggestions will be welcome. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:32 AM |
