front shift rod diameter |
AZBanks |
May 29 2020, 09:28 AM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Are the front shift rods the same diameter for side and tail shift transmissions?
My car is a '71 that was converted to a side shift transmission. I bought the Rix conversion shift bushing from 914 rubber but I can not get it to stay on place when I push the front shift rod through the firewall. It pushes the bushing out. The shift rod diameter where it passes through the firewall is .92 inches, 23.39 mm. What bushing do I need for that size front shift rod? |
ChrisFoley |
May 30 2020, 03:10 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
That's probably not an early tunnel shift rod.
It appears that they sleeved the late rod to fit the original bushing. Get the sleeve off and you might be able to use my bearing. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:45 PM |
