Engine tear down, Engine help |
simonjb |
Mar 26 2020, 07:00 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
So I decided to clean up my original engine while I run the car with a modified scat engine.
When I drained the oil I found these....two small pieces and the nut.....(dime for size). So I started to tear down the top end and found one cylinder that looked not so good. The others are the same as the right side. went down further and removed the pistons and am now cleaning them all up. Everything looks ok. I really don’t want to split the case or go any further and from what I see inside all look good. So two questions.... 1) any thought on why this cylinder isn’t firing right ? 2) can I use something like gasoline or similar to flush and clean out the inside of the case with the crank and oil pump etc still attached? 3) any reason why I can’t use all the old parts ? 4) any thought on the nut? Thanks.... |
Mark Henry |
May 31 2020, 06:14 PM
Ohhh man...that engine stand is a recipe for disaster. (IMG:style_emoticons/default/blink.gif)
Those cheap engine stands are crap, over on the samba a guy sells reasonable priced 3 arm stands. And I hope that bench is screwed to the wall. As soon as you add the weight of the crank and P&C's the whole thing, bench and all, will fall on it's nose. (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 04:53 AM |
