Broken valve spring cylnder #4, Broken valve spring cylnder #4 |
vcolper |
Apr 13 2020, 09:35 AM
Newbie Group: Members Posts: 2 Joined: 2-February 19 From: Florida Member No.: 22,853 Region Association: South East States |
Question:
Can I replace a broken valve spring (Cyl 4) while engine is mounted in car? What tool? Recommendations? Thanks |
HAM Inc |
Apr 15 2020, 04:04 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Over the twenty plus years I worked with used T4 heads I saw a great many come in with a broken spring. The number one cause was rust. Engines that sit for an extended period of time have a problem with this.
Weak springs also are the number one cause of dropped valve seats on T4 heads. The springs are over 40 years old now. If one broke, the others can too. And I would bet my corona stimulus check they're all weak, even if they aren't rusty. |
gtbarnes |
Jun 4 2020, 05:43 PM
Newbie Group: Members Posts: 10 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States |
Over the twenty plus years I worked with used T4 heads I saw a great many come in with a broken spring. The number one cause was rust. Engines that sit for an extended period of time have a problem with this. Weak springs also are the number one cause of dropped valve seats on T4 heads. The springs are over 40 years old now. If one broke, the others can too. And I would bet my corona stimulus check they're all weak, even if they aren't rusty. You are 1000% correct on ALL of that...Now the question is .."Where do you get 4cyl/typ4 valvespring set...or even ONE!!!!!?????ANYONE????HELP??? |
pilothyer |
Jun 4 2020, 06:10 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
[/quote]
You are 1000% correct on ALL of that...Now the question is .."Where do you get 4cyl/typ4 valvespring set...or even ONE!!!!!?????ANYONE????HELP??? [/quote] HERE FOR ONE |
Lo-Fi Version | Time is now: 10th June 2024 - 12:29 AM |
