For flat sixes: Webers v MFI v EFI, Ecologically speaking… |
horizontally-opposed |
Jun 5 2020, 03:34 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Currently have a 2.2E/S with Webers. It runs well and makes good power, having been tuned on the dyno and further dialed in since then, but I have discovered I'm just not a carburetor person. Fuel economy isn't good enough for the size of engine/car, and the emissions bother me—both in terms of the smells in my garage and while driving the car. And yes, we've been totally spoiled by low emissions cars.
What I'm curious about, for anyone who has lived with carbs and MFI: Is MFI noticeably cleaner and/or more efficient than carbs? Or is EFI the way to go? I'm in no hurry on this, but curious for the experiences of others. Yes, Motronic, but I actually like the 2.2 engine. Thanks! (IMG:style_emoticons/default/beerchug.gif) |
mb911 |
Jun 6 2020, 06:52 AM
914 Guru Group: Members Posts: 6,876 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I plan to do 1 of 2 things on my car.. Use my webers as Throttle body's and use the MFI ports in the heads for injector ports or use my restored 3.2 intake and make adapters for the heads and likly use the Bitz racing setup with Megasquirt.. Pretty cheap EFI at that point.
Mark Henry |
Jun 7 2020, 06:34 AM
I plan to do 1 of 2 things on my car.. Use my webers as Throttle body's and use the MFI ports in the heads for injector ports or use my restored 3.2 intake and make adapters for the heads and likly use the Bitz racing setup with Megasquirt.. Pretty cheap EFI at that point. (IMG:style_emoticons/default/agree.gif) that you would be better to sell the webers and use TB's from a Triumph bike. If you still want to use the carb bodies I'd get a pair of Zeinths. With ITB's and big carb cams you will have to run MS in AlphaN (SDS "TPS only") because you won't have good enough vacuum to run the MAP sensor. AlphaN works but tends to make the throttle an on/off switch which is a PITA at lower RPM's such as stop and go traffic. It also disables altitude AFR correction because it works off the MAP sensor. Big cams with large duration is where MFI and carbs shine, this is especially true for hot street engine that sees a fair bit of time at lower RPM. My bug and 914 I run real hot cams, the /4 has SDS EFI with a 163/86B cam and my six 120/104 web cams, The /4 cam with 46mm ITB's has to run in TPS only. The carbs have a much smoother on/off transition compared to the FI. This is for a /4 but you can see how much work it took me to adapt Suzuki GSX-R TB's to carb manifolds in my motorcycle TB's thread. |
Lo-Fi Version | Time is now: 6th June 2024 - 01:23 PM |
