| Tdskip |
Jan 11 2018, 11:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,784 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Good morning, can we pretend for a minute that I was going to do a 914/6 build with a 1974 that is already missing its engine. Further, can we imagine that I would be trying to build a car that would be used rather than showed, and that building a clone and/or a "correct" car is not a goal. The goal would be a well balanced, reliable and sorted out car for backroad touring use.
Does this look like the necessary bits? -2.7 or 3.0l engine with CIS (have this) -engine tin -oil tank -front oil cooler -to/from oil cooler lines -throttle linkage -fuel pump -fuel lines -engine lid latch relocation bits (due to CIS) -headers -flywheel -ECU -CDI box -O2 sensor -Engine mount -320i front brakes since the extra horsepower probably deserves it Edit - adding these from Cario and Defianty muffler thermostat for the oil cooler gauges to work with new engine Filler neck for the oil tank Oil dipstick Oil filter console Six muffler 19mm master cylinder FI harness (missed that one) Edit - adding from Lucky9146 Conversion Wiring harness? 914-6 trans mid-plate for throttle or some other contraption, not sure w/FI Shift Rod modified for headers Oil cooler thermostat Oil cooler shroud Oil Cooler Fans Oil Fed chain tensioners Edit - adding from mb911 headers or heat exchangers Am I missing anything? I did try searching and reading prior discussions. Thanks! |
| Tdskip |
Jul 12 2019, 07:13 AM
| Jonathan Livesay |
Jun 11 2020, 01:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 746 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None
Tdskip Look like the right list of bits for a 914/6 build Jan 11 2018, 11:25 AM
Cairo94507 That's a pretty good start. You might want to... Jan 11 2018, 11:31 AM
defianty Yep that's a good list to start, here's a ... Jan 11 2018, 11:36 AM
Tdskip Thanks gentlemen.
@Cario, thanks for pointing out... Jan 11 2018, 11:48 AM
tomeric914 Take a look at my build thread for some ideas. Mi... Jan 11 2018, 11:51 AM
Tdskip
Take a look at my build thread for some ideas. M... Jan 11 2018, 11:51 AM
mepstein Horsepower has nothing to do with needing bigger b... Jan 11 2018, 12:17 PM
Tdskip
Horsepower has nothing to do with needing bigger ... Jan 11 2018, 03:53 PM
Lucky9146 Yes good start.
Probably need:
Conversion Wiring... Jan 11 2018, 12:19 PM
Tdskip
Yes good start.
Probably need:
Conversion Wirin... Jan 11 2018, 04:02 PM
burton73 Do you have the car yet?
I seem to remember you g... Jan 11 2018, 03:18 PM
Tdskip
I seem to remember you ... Jan 11 2018, 03:59 PM
Tdskip Here she is...
Jan 11 2018, 04:03 PM
mb911 Great list also 6 headers or heatexchangers will b... Jan 11 2018, 04:21 PM
Tdskip
Great list also 6 headers or heatexchangers will ... Jan 11 2018, 05:17 PM
barefoot If you're sticking with the CIS and want O2 se... Jan 11 2018, 04:48 PM
Tdskip
If you're sticking with the CIS and want O2 s... Jan 11 2018, 05:19 PM
burton73 You are on your way. Great guys that will help you... Jan 11 2018, 05:25 PM
Tdskip
You are on your way. Great guys that will help yo... Jan 11 2018, 05:30 PM
mepstein CIS, in Good working condition, makes for a nice d... Jan 11 2018, 06:18 PM
Tdskip
CIS, in Good working condition, makes for a nice ... Jan 11 2018, 06:48 PM
mb911 How about patience and overage money and more pati... Jan 11 2018, 06:19 PM
Tdskip
How about patience and overage money and more pat... Jan 11 2018, 06:49 PM
burton73
How about patience and overage money and more pa... Jan 11 2018, 10:31 PM
Larmo63 Money, and patience.
I almost gave up on my conve... Jan 12 2018, 12:13 AM
Tdskip
I almost gave up on my conv... Jan 12 2018, 08:40 AM
I almost gave up on my con... Jan 12 2018, 08:48 AM
GeorgeRud Though you have warm weather in California, you st... Jan 12 2018, 09:02 AM
Mark Henry I'd vote 3.0 as well, it's what I have, bu... Jan 12 2018, 09:04 AM
Tdskip
I'd vote 3.0 as well, it's what I have, b... Jan 12 2018, 01:55 PM
Mark Henry You also need a 914 oil cooler or a 911 cooler mod... Jan 12 2018, 06:05 PM
Tdskip
You also need a 914 oil cooler or a 911 cooler mo... Jan 12 2018, 10:01 PM
Tdskip OK - to try and get myself organized and start hun... Jan 12 2018, 10:14 PM
porschetub
OK - to try and get myself organized and start hu... Jan 13 2018, 12:23 AM
Blue6
Great list also 6 headers or heatexchangers will... Jan 12 2018, 10:42 PM
Tdskip
If you skip the heat exchangers, just add seat he... Jan 12 2018, 10:54 PM
raynekat Perry Kiehl (on this website) will build you a kil... Jan 12 2018, 11:51 PM
Tdskip Wait - Forrest is on here? Great.
I know him, I w... Jan 13 2018, 06:58 AM
mepstein 914-6 trans mid-plate for throttle or some other c... Jan 13 2018, 07:15 AM
Tdskip
914-6 trans mid-plate for throttle or some other ... Jan 13 2018, 07:56 AM
mb911 Tom,
I am going to try to call you today to talk ... Jan 13 2018, 08:44 AM
Tdskip
Tom,
I am going to try to call you today to talk... Jan 13 2018, 08:45 AM
Tdskip Good morning. Quick follow-on question;
I sourced... Jan 19 2018, 06:52 AM
mb911 Did you decide to run a 3.0? I would don't rec... Jan 19 2018, 06:03 PM
Tdskip
Did you decide to run a 3.0? I would don't re... Jan 19 2018, 06:10 PM
Tdskip OK - time for an update here.
I've decided to... Mar 8 2018, 05:09 PM
I've decided t... Mar 8 2018, 05:53 PM
Tdskip
I've decided ... Mar 8 2018, 06:42 PM
mb911
[quote name='mepstein' post='2587087' date='Mar 8... Mar 9 2018, 06:11 AM
mb911 You will now for sure want 1.625 heat exchangers..... Mar 8 2018, 06:24 PM
mepstein You don’t need a custom engine harnes with a 3.2... Mar 8 2018, 07:05 PM
Tdskip
You don’t need a custom engine harnes with a 3.... Mar 9 2018, 10:13 AM
I have made pretty good progress on... Apr 9 2018, 07:49 AM
Cairo94507 Outstanding progress on getting all of your parts ... Apr 9 2018, 08:40 AM
Tdskip
Outstanding progress on getting all of your parts... Apr 9 2018, 09:03 AM
mb911 Let me know what you decided on headers or heatexc... Apr 9 2018, 12:04 PM
GeorgeRud Ben should have oil cooler lines and ducting for y... Apr 9 2018, 02:48 PM
Larmo63 Did this build go over the cliff?
What happened h... May 30 2019, 09:08 PM
Tdskip
What happened ... Jul 12 2019, 07:06 AM
Tdskip RE: Look like the right list of bits for a 914/6 build Jul 12 2019, 07:09 AM
Tdskip Dusting this off as I don't believe I asked ab... Jun 11 2020, 01:26 PM
mepstein Yes. I would have the one with the engine checked ... Jun 11 2020, 01:33 PM
Tdskip
Yes. I would have the one with the engine checked... Jun 11 2020, 01:42 PM
Yes. I would have the one with the engine checke... Jun 11 2020, 02:25 PM
Tdskip Been a while but getting serious about getting the... Sep 16 2020, 07:50 PM
porschetub Good to see you are getting on with it :D ,someon... Sep 17 2020, 05:14 PM
Tdskip Thanks mate, appreciate the response.
I’ve seen... Sep 17 2020, 05:20 PM
Mark Henry Dan Roots template that I used, set printer at 8.5... Sep 18 2020, 08:18 AM
Mark Henry dp Sep 18 2020, 08:34 AM
Tdskip Thank you Mark! Sep 18 2020, 08:43 AM
Tdskip Got some good news today, the shop going through t... Sep 25 2020, 06:18 PM
nditiz1 Thats great news.
Sell the Naro and get the OEM s... Sep 25 2020, 07:09 PM
Tdskip It’s in.
Oct 24 2020, 02:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2026 - 12:50 PM |
