rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,309 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Drove around for 30 minutes in 80+ degree weather. All arterial roads, so several stop lights, etc. No problems until I was almost home. Car stalled when I stopped at a light. RPMs just dropped to zero. Was able to start it again with a little difficulty and had to keep my foot on the gas to keep it from stalling out again. Power seemed ok though the rest of the way home (I think). It stalled once again at a stop light a couple of blocks from home and then again when I pulled in the driveway. I let it sit for 30 seconds, started it again and it idled just fine. Rock solid at 1000 RPMs. Pulled it into the garage where it sits now.
Prior to today the car has been running and idling perfectly since I went through the FI parts last year, which included installing a 123 distributor, new CHT sensor, a newly rebuilt mps (calibrated for correct afr on my engine), new vacuum hoses, NOS throttle body, rebuilt injectors, new fuel pump, valve adjustment and timing. I haven’t checked the AFR since last year, not sure why it would change though. It’s a ‘75 so the fuel pump is in the front, so I can rule out vapor lock I think. Anyone have ideas as to why it would be stalling? |
bzettner |
Member ![]() ![]() Group: Members Posts: 213 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region ![]() |
I read thru this yesterday but can't remember if you've rechecked the fuel pressure recently?
rjames |
I read thru this yesterday but can't remember if you've rechecked the fuel pressure recently? I don't have a gauge to test, but it's on the list of things to check. That said, if fuel pressure was an issue, I would expect to see issues when I am at partial load or WOT, and not at idle when fuel pressure is lowest, no? |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,954 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
I read thru this yesterday but can't remember if you've rechecked the fuel pressure recently? I don't have a gauge to test, but it's on the list of things to check. That said, if fuel pressure was an issue, I would expect to see issues when I am at partial load or WOT, and not at idle when fuel pressure is lowest, no? Fuel pressure is constant on stock setup. Most newer fuel pressure regulators do lower pressure at idle based on manifold vacuum, but not our stock unit. It's worth checking. Unfortunately you've run out of obvious and simple things to check. Now you need to make a list and check it twice... |
Lo-Fi Version | Time is now: 8th July 2025 - 09:55 PM |
