Bumper fitment issues |
mb911 |
Jun 13 2020, 03:49 PM
914 Guru Group: Members Posts: 6,879 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am wondering if its a bumper top, bumper or car? The top is 914 rubber and was bought a year or so ago. The car is not bashed in any wear and the bumper was rechromed by Oscar about a year ago. It fits the same way on both sides starting at the headlights towards the out fender. Again both sides are the same.
Olympic 914 |
Jun 14 2020, 09:17 AM
Group: Members Posts: 1,675 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Using allthread instead of the bolts makes the installation easier. Then if you like you can remove the allthread one at a time and replace the bolts. cutting a screwdriver slot in the end of the allthread helps when removing them.
My car had work done in the bumper mount area on both sides so I had to adjust the rubber dogbone thickness to get the fit right. |
mb911 |
Jun 14 2020, 10:18 AM
Using allthread instead of the bolts makes the installation easier. Then if you like you can remove the allthread one at a time and replace the bolts. cutting a screwdriver slot in the end of the allthread helps when removing them. My car had work done in the bumper mount area on both sides so I had to adjust the rubber dogbone thickness to get the fit right. Another good idea |
Lo-Fi Version | Time is now: 7th June 2024 - 01:59 AM |
