What's my junk worth? |
Franky_Four_Fingers |
Jun 14 2020, 05:41 PM
Where is the stoooone? Group: Members Posts: 19 Joined: 15-April 18 From: Chicago Member No.: 22,041 Region Association: Upper MidWest |
Hoping I can tap into the collective knowledge here:
I bought a 1971 914 which was built and raced in CVAR about a year ago and would like to continue my plans to create a GT tribute. The car came with a fresh 1.7 which I'm told was enlarged to a 1.9. The transmission (side-shift) was rebuilt and modified to be "close ratio". There was also some top-end mods done in 2018 in an attempt to find more HP. I will post what info I have below, but I'm hoping some of you might help me identify what I have and what it's worth. My other question is whether or not I should keep the modified transmission or run the stock rebuilt 901 that I have. I'm planning to install a 2.2 with moderate cams and carbs. TIA Info from the build sheet: Engine: New Weber 40 IDF’s / EMPI Manifolds & Linkage / New Distributor Cap / Coil / Wires / Points / Plugs / New Euro Racing Matched Length Headers and Megaphone Exhaust. Heads overhauled by HFM 9:1 compression cut, New Pushrod Tubes and Viton Seals. New SCAT Hi Capacity Oil Sump. Transmission: Internals Rebuilt by Joe Cogbill: Close ratio 4/5 gears installed, all new syncros, diff seals and gaskets. Shift linkage re-bushed and adjusted. In case anyone here knows the car, I will post a pic. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:02 AM |
