Possible bad fuel pump, Don't think it's vapor lock...but??? |
Ampex351 |
Jun 14 2020, 05:58 PM
Member Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest |
We took the car out for a ride today and she did fine until 40 minutes later. Just started acting like it was starving for gas then stopped running altogether.
Let it sit a few minutes thinking maybe vapor lock. Started and headed for home. Made it 2 miles and the same thing happened...just starving for fuel...then dies. Now when I turn the key on there is no sound of the fuel pump. Usually make a little humming noise. This car had sat for nearly 8 years before I bought it. Possible bad fuel pump? What would you think? Thanks |
SirAndy |
Jun 14 2020, 06:41 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
We took the car out for a ride today and she did fine until 40 minutes later. Just started acting like it was starving for gas then stopped running altogether. Let it sit a few minutes thinking maybe vapor lock. Started and headed for home. Made it 2 miles and the same thing happened...just starving for fuel...then dies. Now when I turn the key on there is no sound of the fuel pump. Usually make a little humming noise. This car had sat for nearly 8 years before I bought it. Possible bad fuel pump? What would you think? Thanks Could also be electrical. Is this stock FI? D-Jet? L-Jet? Carb conversion? Is your relay board in good shape? Any cracks in the tar on the bottom side? What about the relays on the board? Did you switch the fuel pump relay to a known to be good one? One of the headlight relays will do. (IMG:style_emoticons/default/idea.gif) |
Ampex351 |
Jun 14 2020, 06:50 PM
We took the car out for a ride today and she did fine until 40 minutes later. Just started acting like it was starving for gas then stopped running altogether. Let it sit a few minutes thinking maybe vapor lock. Started and headed for home. Made it 2 miles and the same thing happened...just starving for fuel...then dies. Now when I turn the key on there is no sound of the fuel pump. Usually make a little humming noise. This car had sat for nearly 8 years before I bought it. Possible bad fuel pump? What would you think? Thanks Could also be electrical. Is this stock FI? D-Jet? L-Jet? Carb conversion? Is your relay board in good shape? Any cracks in the tar on the bottom side? What about the relays on the board? Did you switch the fuel pump relay to a known to be good one? One of the headlight relays will do. (IMG:style_emoticons/default/idea.gif) Stock '73 2.0 Is the relay board inside that metal housing box by the battery? Are the relays inside it? I haven't looked inside of the box yet. Rain coming for 2 days so will have to wait to do that. Is it possibly the fuel pump has gone bad after sitting for so many years? |
Lo-Fi Version | Time is now: 6th June 2024 - 12:57 PM |
