| AZBanks |
Jun 15 2020, 01:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region
I installed a replacement transmission in the 71.
I may have overfilled the trans. Would the excess trans oil leak out the axle and front seals or does the presence of leaks mean I need to replace the seals?? |
| GregAmy |
Jun 15 2020, 01:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,677 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
I'm not sure how it's possible to overfill the transaxle unless you did it without it out of the car. You're pouring oil into the upper plug and once it starts to spill out you stop.
Did you attempt to fill via the vent on top of the transaxle? |
| AZBanks |
Jun 15 2020, 02:21 PM
I'm not sure how it's possible to overfill the transaxle unless you did it without it out of the car. You're pouring oil into the upper plug and once it starts to spill out you stop. Did you attempt to fill via the vent on top of the transaxle? I was using a funnel that fit the fill hole really tight. I had the funnel angled up. When I pulled the funnel I got a lot of oil every where, If I had been thinking, I would have let the excess drain out. I was more worried about the mess so I put the drain plug in as fast as I could. It is not massively over filled, just a little. Maybe 1/4" above the bottom of the fill hole. My main question is if just being overfilled would cause the leaks or if I need to replace the seals. I am only getting a few drops on the floor after a drive. My initial guess is that I need to drain the new oil I just put in, replace the seals and then fill it again. |
AZBanks Overfilled the transmission Jun 15 2020, 01:25 PM
911GT2
I installed a replacement transmission in the 71.... Jun 15 2020, 01:29 PM
Frankvw just take out the fillplug and let the surplus com... Jun 15 2020, 01:30 PM
GregAmy I suppose it's possible that, with only ... Jun 15 2020, 03:16 PM
Tdskip
I suppose it's possible that, with only ... Jun 15 2020, 04:29 PM
porschetub Also make sure the top vent is clear....it could b... Jun 15 2020, 04:11 PM
PlaysWithCars
Also make sure the top vent is clear....it could ... Jun 15 2020, 10:46 PM
AZBanks The trans was leaking out of the input shaft seal.... Oct 9 2020, 01:21 AM
Tdskip
The trans was leaking out of the input shaft seal... Oct 9 2020, 06:07 AM
ndfrigi
The trans was leaking out of the input shaft seal... Oct 9 2020, 09:50 AM
AZBanks Thanks for the suggestions.
It is the old seals ... Oct 9 2020, 07:25 PM
ndfrigi Are you draining the gear oil? I don’t you need ... Oct 9 2020, 07:36 PM
AZBanks Dr. Evil said not to use Swepco, He says the best ... Oct 9 2020, 07:45 PM
iankarr Try putting a screw or two into the old seal to gi... Oct 9 2020, 07:50 PM
AZBanks I bought a cheap harbor freight seal puller. It wo... Oct 9 2020, 10:51 PM
AZBanks In my "front engine 914" thread I docume... Oct 17 2020, 08:14 PM
mrholland2
In my "front engine 914" thread I docum... Oct 20 2020, 09:39 AM
AZBanks
In my "front engine 914" thread I docu... Oct 20 2020, 11:25 AM
michael7810 I had similar experience getting mine thru emissio... Oct 18 2020, 07:36 AM
AZBanks Arizona has seriously messed up classic car regist... Oct 19 2020, 02:00 AM
bandjoey Just and FYI on insurance Haggerty never asked... Oct 19 2020, 11:37 PM
AZBanks
Just and FYI on insurance Haggerty never aske... Oct 20 2020, 02:25 AM
AZBanks
Just and FYI on insurance Haggerty never aske... Dec 7 2020, 05:47 PM
914e
Just and FYI on insurance Haggerty never ask... Dec 7 2020, 10:30 PM
AZBanks Since the exhaust is off while the trans is out, I... Oct 20 2020, 02:28 AM
AZBanks Nothing like a professional wrap job.
Oct 20 2020, 02:30 AM
AZBanks Yeah, really, this is NOTHING like a professional ... Oct 20 2020, 02:31 AM
VaccaRabite Why did you wrap it?
That wrap holds oil and greas... Oct 20 2020, 07:27 AM
AZBanks
That wrap holds oil and grea... Oct 20 2020, 01:47 PM
AZBanks I got the trans back in the car and everything els... Nov 1 2020, 01:12 AM
VaccaRabite Yeah collector car insurance wants each driver to ... Dec 8 2020, 12:16 PM
AZBanks I get their reasoning for most people but not ever... Dec 9 2020, 03:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd June 2026 - 10:58 PM |
