| AZBanks |
Jun 15 2020, 01:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region
I installed a replacement transmission in the 71.
I may have overfilled the trans. Would the excess trans oil leak out the axle and front seals or does the presence of leaks mean I need to replace the seals?? |
| GregAmy |
Jun 15 2020, 03:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,677 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
I suppose it's possible that, with only "a few drops", it could just be splash overflow from the vent at the top.
Don't waste the oil you put in, try the easy stuff first. Simply let the car sit on the ground level, put a drain pan under the transaxle, and remove the fill (top) plug. Let it drain until it stops pouring out (it's not an exact science, just needs to be around the bottom level of the hole) and reinstall the plug. Then drive it. |
| Tdskip |
Jun 15 2020, 04:29 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
I suppose it's possible that, with only "a few drops", it could just be splash overflow from the vent at the top. Don't waste the oil you put in, try the easy stuff first. Simply let the car sit on the ground level, put a drain pan under the transaxle, and remove the fill (top) plug. Let it drain until it stops pouring out (it's not an exact science, just needs to be around the bottom level of the hole) and reinstall the plug. Then drive it. As Greg and others mentioned this is the way to do it. Don't sweat it on it being exactly the perfect amount of oil in there, once it stops draining out on a level surface you are good. Let us know how you get on. |
AZBanks Overfilled the transmission Jun 15 2020, 01:25 PM
911GT2
I installed a replacement transmission in the 71.... Jun 15 2020, 01:29 PM
Frankvw just take out the fillplug and let the surplus com... Jun 15 2020, 01:30 PM
GregAmy I'm not sure how it's possible to overfill... Jun 15 2020, 01:44 PM
AZBanks
I'm not sure how it's possible to overfil... Jun 15 2020, 02:21 PM
porschetub Also make sure the top vent is clear....it could b... Jun 15 2020, 04:11 PM
PlaysWithCars
Also make sure the top vent is clear....it could ... Jun 15 2020, 10:46 PM
AZBanks The trans was leaking out of the input shaft seal.... Oct 9 2020, 01:21 AM
Tdskip
The trans was leaking out of the input shaft seal... Oct 9 2020, 06:07 AM
ndfrigi
The trans was leaking out of the input shaft seal... Oct 9 2020, 09:50 AM
AZBanks Thanks for the suggestions.
It is the old seals ... Oct 9 2020, 07:25 PM
ndfrigi Are you draining the gear oil? I don’t you need ... Oct 9 2020, 07:36 PM
AZBanks Dr. Evil said not to use Swepco, He says the best ... Oct 9 2020, 07:45 PM
iankarr Try putting a screw or two into the old seal to gi... Oct 9 2020, 07:50 PM
AZBanks I bought a cheap harbor freight seal puller. It wo... Oct 9 2020, 10:51 PM
AZBanks In my "front engine 914" thread I docume... Oct 17 2020, 08:14 PM
mrholland2
In my "front engine 914" thread I docum... Oct 20 2020, 09:39 AM
AZBanks
In my "front engine 914" thread I docu... Oct 20 2020, 11:25 AM
michael7810 I had similar experience getting mine thru emissio... Oct 18 2020, 07:36 AM
AZBanks Arizona has seriously messed up classic car regist... Oct 19 2020, 02:00 AM
bandjoey Just and FYI on insurance Haggerty never asked... Oct 19 2020, 11:37 PM
AZBanks
Just and FYI on insurance Haggerty never aske... Oct 20 2020, 02:25 AM
AZBanks
Just and FYI on insurance Haggerty never aske... Dec 7 2020, 05:47 PM
914e
Just and FYI on insurance Haggerty never ask... Dec 7 2020, 10:30 PM
AZBanks Since the exhaust is off while the trans is out, I... Oct 20 2020, 02:28 AM
AZBanks Nothing like a professional wrap job.
Oct 20 2020, 02:30 AM
AZBanks Yeah, really, this is NOTHING like a professional ... Oct 20 2020, 02:31 AM
VaccaRabite Why did you wrap it?
That wrap holds oil and greas... Oct 20 2020, 07:27 AM
AZBanks
That wrap holds oil and grea... Oct 20 2020, 01:47 PM
AZBanks I got the trans back in the car and everything els... Nov 1 2020, 01:12 AM
VaccaRabite Yeah collector car insurance wants each driver to ... Dec 8 2020, 12:16 PM
AZBanks I get their reasoning for most people but not ever... Dec 9 2020, 03:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd June 2026 - 12:17 AM |
