MPS testing/adjustment problem. Can't get anything higher than 0.9 H |
scottthephotog |
Jun 16 2020, 05:59 PM
Member Group: Members Posts: 187 Joined: 20-November 18 From: Euless, TX Member No.: 22,667 Region Association: Southwest Region |
I've been following this explanation and walkthrough of testing the MPS; https://members.rennlist.com/pbanders/manif...sure_sensor.htm, and I've come across a problem.
My MPS holds vacuum, I've got correct resistance readings on each of the coils, confirmed that they were isolated properly, so I moved on to adjusting. At 15 in. Hg, reading were correct (.71H). I found that I couldn't get the MPS to reach any higher than 0.9 H with my inductance meter at either the 4 in Hg or 0 in. Hg. I pulled the MPS apart, and measured again with it open (nothing pushing back on the main armature shaft with the armature shaft stops in place). The armature stops don't appear to be bent. With the armature shaft pushed in all the way, I get a reading of 0.45 H. Any thoughts? Is this MPS toast? I can't figure out why it won't register more than 0.9 H, which i way off from 1.44 H. |
JeffBowlsby |
Jun 16 2020, 08:29 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I am not sure why because I know he accessed and characterized NOS and good used, unopened MPSs, but the Anders numbers are known to be too low, even withe the Wavetek meter.
BTW the better vacuum test and calibration uses data points up to 18inHg |
Lo-Fi Version | Time is now: 4th June 2024 - 10:10 AM |
