| nditiz1 |
Jun 29 2020, 02:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,272 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region
So doing a valve adjustment i found #3 intake to be very loose. I started to adjust and then found this. Why/how did this happen?
Also, why are my leakdown tests consistently 20% leaking through the case? Rings? I did it cold and the engine looks to be rebuilt from how clean the inside of the heads were. |
| porschetub |
Jun 29 2020, 03:26 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,209 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
So doing a valve adjustment i found #3 intake to be very loose. I started to adjust and then found this. Why/how did this happen? Also, why are my leakdown tests consistently 20% leaking through the case? Rings? I did it cold and the engine looks to be rebuilt from how clean the inside of the heads were. The adjusters do wear,once the hardening has broken away you get your problem,this is often compounded by too much clearance. I never refit adjustment screws that are too worn,its just not worth it,you will need to check the end (tip) of the inlet valve isn't damaged which I fear might be the case. Try a compression test with the engine up to temp ,a cold air cooled engine takes up a fair amount with expansion,if your leakdown test is even 20% it will improve when hot so you should be fine. Good luck. |
nditiz1 Valve adjuster squashed Jun 29 2020, 02:45 PM
BillC My guess is that you got a defective adjuster scre... Jun 29 2020, 03:05 PM
burton73
My guess is that you got a defective adjuster scr... Jun 29 2020, 04:53 PM
nditiz1 Thanks!
The valve had a slight knick on the e... Jun 29 2020, 04:00 PM
porschetub
Thanks!
The valve had a slight knick on the ... Jun 29 2020, 05:46 PM
brant as an unknown (to you) motor
it might be worth doi... Jun 29 2020, 04:13 PM
nditiz1 That stinks Bob.
So I put a good used one in its ... Jun 29 2020, 05:36 PM
porschetub
That stinks Bob.
So I put a good used one in its... Jun 29 2020, 05:55 PM
RoadGlue
Shit that's not good,looks like the pushrod r... Jun 29 2020, 08:07 PM
porschetub
Shit that's not good,looks like the pushrod ... Jun 30 2020, 01:17 AM
Jake Raby That valve adjuster was made of Chinadium...... Jul 4 2020, 06:26 PM
nditiz1
... Jul 4 2020, 08:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th November 2026 - 10:33 PM |
