| macnichol |
Jun 29 2020, 02:25 PM
Newbie ![]() Group: Members Posts: 40 Joined: 12-June 20 From: Indianapolis, IN Member No.: 24,372 Region Association: NineFourteenerVille |
Hi, saw these cracks on my project 914, are these any cause for concern?
Attached thumbnail(s) |
| davep |
Jul 1 2020, 02:18 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,377 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Okay, first of all since the car is a 1970, what is the VIN? If the VIN is very early. say under 500, then there is the possibility that there was no gap in there originally. After about the first 450 cars they had the gap with the plastic filler. If the panels are getting loose, or just rotting underneath then cracks can appear and rust sets in. You will need to get everything down to good metal and see what damage has to be repaired. First though, you need to know which fender & cowl version you have. Also, try and get a photo of the paint badge on the L door hinge post. The upper set of numbers is a body #, and the lower is the paint code. If too hard to photograph, just report all the numbers to me.
macnichol Potentially concerning cracks in between front quarter panel and door area Jun 29 2020, 02:25 PM
nditiz1 They are supposed to be there and someone put fill... Jun 29 2020, 02:30 PM
bbrock Looks like somebody filled that seam with bondo. ... Jun 29 2020, 02:30 PM
brant looks like bondo most likely
the cowl area may be... Jun 29 2020, 02:30 PM
Mikey914 Dig what you can out and survey. Maybe you will ge... Jun 29 2020, 02:58 PM
Tdskip Welcome and don’t be shy with questions. Jun 29 2020, 03:34 PM
UROpartsman What's the best way to remove Bondo in a seam ... Jun 29 2020, 04:14 PM
dakotaewing Be careful not to "Buger up" the inside ... Jun 29 2020, 04:33 PM
tvdinnerbythepool
This is what it should look like for reference.... Jun 29 2020, 05:51 PM
FlacaProductions And here's where to get it - and what the seal... Jun 29 2020, 06:04 PM
roblav1 Since the front fenders are spot welded on anyway,... Jun 29 2020, 08:13 PM
framos914 Another possibility is that the hood flew open whi... Jun 29 2020, 10:25 PM
Mikey914 Now that I look at it closer you have something lu... Jul 1 2020, 12:56 AM
windforfun I removed those plastic "seals" a long t... Jul 1 2020, 03:37 PM
Mikey914 One of the reasons we made ours rubber :D Jul 1 2020, 04:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th October 2026 - 08:07 PM |
