Carbon canister on top of fuel tank |
356drb |
Jun 22 2020, 01:49 PM
Newbie Group: Members Posts: 43 Joined: 4-April 20 From: Indianapolis Member No.: 24,101 Region Association: None |
The fuel tank change occurred in April/May 1974. The carbon canister moved off the top of the fuel tank prior to this change. Was it at the end of calendar year 1973 or at the model change in the summer of 1973?
wonkipop |
Jul 2 2020, 04:59 PM
Advanced Member Group: Members Posts: 4,403 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
@ starbear.
your car is a 2.0? they must have had provision in the body shells for the changeover to engine bay cannister before the new calendar year commenced. admittedly fairly minor changes to the shell. they seem to be doing two things in 74. first changing to a plastic evap cannister (i might be wrong) and then changing its position (3 times?). wonder if the plastic cannister worked up front properly on L jet 1.8 cars. its the first time airflow meter system is used on a car. engine fan did pressurize (not much admittedly) the evap cannister that leads into the air cleaner up stream of the meter flap. must influence the system? maybe only minor? they moved that cannister around 3 times in a very short period of time. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:46 PM |
