LED Dash Dimmer Circuit Project, Need to know the resistance of the Light dimmer potentiometer |
Spoke |
Jul 3 2020, 09:28 AM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I've been working on a circuit to allow the use of LEDs for dashboard instrument lighting and give complete dimming from 100% down to 1-5%. The circuit will provide a PWM output and will work with LEDs and incandescent bulbs.
Circuit simulations show very good functionality and linearity over the full range of dimmer adjustment. Since the light switch potentiometer is relatively low resistance, when changing to LED dash lights, the LEDs tend to dim just a bit then turn off. This circuit would provide a ballast resistor to sense the change in resistance of the pot. One thing I need though is the range of resistance of the potentiometer of the light switch. If anyone has a light switch laying around, I would appreciate a measurement of the resistance from bright to off. It looks like the pins for the pot are 58b (12V power) and 58a (dimmed output to the bulbs). |
914werke |
Jul 3 2020, 10:15 AM
"I got blisters on me fingers" Group: Members Posts: 10,145 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
quick chk with my cheap dvm 200ohm range is from 3.5-27
Spoke |
Jul 3 2020, 12:38 PM
quick chk with my cheap dvm 200ohm range is from 3.5-27 Ugh. I was hoping the resistance would be a bit higher. If I want a 3V drop with the maximum resistance (27 ohm), then I'll need a ballast resistor of 99 ohm and current of 111ma. The maximum power dissipation with 99 ohm ballast resistor is 2W. That is massive for a small board. Plus it's just wasted power as all it's doing is dropping voltage across the pot. Given the power dissipation, if I divide up the 2W across, say 6 resistors, they would each drop 0.33W. I could use 2512 sized surface mount resistors which are capable of 1W power dissipation. |
Lo-Fi Version | Time is now: 11th June 2024 - 04:16 AM |
