Stripped exhaust stud on fresh rebuilt heads, Fireworks at my place tonight |
djway |
Jul 5 2020, 01:40 AM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Soooooo
I am installing the exhaust manifolds today, using the nice little copper coated exhaust nuts from Bel Metric and at the point the self locking threads encounter the stud, the stud just starts turning. Little effort to pull it out and the stud is clean, no material in the threads. Now mind you that these heads have just been rebuilt and fixing exhaust studs was on the to do list and the cost was substantial to me. Then the fireworks went off... (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/hissyfit.gif) As the great poet Eric Burdon said in the song PC3 "I rattled so long And rattled so obscene The ground did shake And disturbed the Queen..." This is the motor in my Notchback and it has taken too long to squeeze that puppy in there so this fix is going to be in site. Is it an optical illusion or are the studs at an angle? ie not perpendicular to the ground? I ordered some EZLOCK solid inserts and I will make a drill guide that will bolt onto the other stud. Apologies to the neighbors (IMG:style_emoticons/default/blink.gif) |
JamesM |
Jul 5 2020, 01:07 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
using the nice little copper coated exhaust nuts from Bel Metric and at the point the self locking threads encounter the stud, the stud just starts turning. One of the reasons i stopped using any sort of lock nut on the exhaust studs. If they dont pull the studs when installing they absolutely will when removing. These have been my go-to nut for a few years now: http://vwparts.aircooled.net/ACN-Flanged-R...-p/acn-nuts.htm Another tip that not everyone seems to know is never use anything more than a single hand on a small 1/4" driver when installing the exhaust as its makes it more difficult to over torque them (it takes a surprisingly small amount of torque to strip the heads). Also anneal the copper rings before installation. Most leaks are caused by misalignment of the heat exchangers, not the nuts being to loose. Sorry to hear of you troubles though, I have been in that position a few times with 914s over the years. Last time was on a car i discovered a previous "fix" from a PO that after they stripped the head they replaced the stud with an oversized allen head bolt and even cut half the mounting flange off the heat exchanger to make it fit. knowing from multiple past experiences what a PITA dealing with stripped heads in the car can be i just wound up swapping the whole motor. On the plus side, that timecert should be a hell of a lot stronger. Another option depending on how much meat is left in the bore and if you can find them are the 8mm-10mm step studs. I have used a couple of those in the past with good results. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:09 AM |
