Type IV upgrades and FI, Where's the cut-off to carbs? |
boxsterfan |
Jan 7 2014, 12:42 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
At some point, my motor (1974 2.0L) will need a rebuild. I'm not going to go the /6 conversion on this car. If I rebuild the motor to a 2056 or 2270 displacement, can I still use the FI system (D-jet)? Or is there some spot in here where it is better to switch to carbs? Or if I wanted to have FI then switching to L-Jet instead?
Happy to do some reading if you have it... (IMG:style_emoticons/default/chowtime.gif) |
scottthephotog |
Jul 5 2020, 05:16 PM
Member Group: Members Posts: 187 Joined: 20-November 18 From: Euless, TX Member No.: 22,667 Region Association: Southwest Region |
Just some thoughts. I've recently been tuning my 2056cc with D-Jet. I was running rich and with an AFR meter I discovered I was running about 10:1 AFR across the entire throttle range. I have since leaned it out.
I've seen people say D-Jet was used on up to 2.4L engines and with how rich I was able to get the mixture, I'd imagine you could actually get it to work with a 2270 engine. As others have said, it will take more to keep that larger engine cooler. |
Lo-Fi Version | Time is now: 7th June 2024 - 03:51 AM |
