Heat shed, what am I missing to cool her down?, *Update - 1st Test Run after cleanup - still HOT |
nditiz1 |
Jul 5 2020, 09:41 AM
Senior Member Group: Members Posts: 1,190 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Update - pass side tin removed. Signs of leakage.
*Update* - Webers were successful in scooting the teener down the road, but head temps still reached 400, engine drop to follow shortly. Stock 2.0 Engine Converted to carbs - (Dual 40 Dells - 60 Idle jet) Engine tin in place - needs seal on the passenger side Thermostat - dead/expanded - flaps auto spring to full open Valves set .006/.008 Timing 28 - New Pertronix SVDA - vac plugged when timed to 28 No AFR setup - want to say rich not lean New plugs NGK B6ES gapped to .028 *Updated info based on comments* Oil pressure when hot 40 PSI at 4k - so looks ok Oil currently in the block unknown - dark lol, but within the min and max marks Targa was on during test run Deflection flaps present Cooling fan has 1 broken fin CHT gauge is Dakota Digital under cyl#3 spark plug Engine lid is currently off - Dealer installed AC - Box and grate still in place - is this robbing the cool air from under the car at speed? Running oil temp 240/250F 85F ambient temp Head temps in 4th on flat cruising at 65 mph at 4k RPM - *400 and climbing if going up a hill Head temps in 3rd up and down hills *395, but can hit 400 if I get on it just a little Compression test was Cyl #1 - 135 Cyl #2 - 135 Cyl #3 - 130 - CHT temp sensor Cyl #4 - 135 Assuming the carbs are not lean (went 3 turns out, and now went to 4) what should I check next? I thought maybe I needed a rebuild since the compression numbers cold were around 125 with with a 12 psi gap between 2 of the cylinders, but this warm compression check looks healthy. The plugs do look a little white, but the last run I did was in the garage with it running at idle and some briefs to 3500 RPM to ensure the timing was correct. I know this is not to preferred method to check plugs as they should be done driving regularly and then shut off the engine and not let it idle to get a true reading. I have a gas tester I can maybe hook up to check the CO2 at the tail pipe (yes, I should have an AFR to get better readings) In the garage I was running at 350 head temp just at idle ambient temps 82. I know sitting has no air flow. I feel like when I rebuilt my last 2056, I could idle in the garage all day long at 300 or under. Let's assume the carbs are rich enough in the mixture so as to not be lean, will the engine seals being tattered and 1 missing (most crucial side (IMG:style_emoticons/default/dry.gif) ) be enough to make even back road driving push cyl 3 head temps to 400 and above? Plugs - less than 50 miles - maybe not enough time Cyl 1 and 2 (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1593964487.1.jpg) Cyl 3 and 4 (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1593964488.2.jpg) |
VaccaRabite |
Jul 6 2020, 08:09 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
This sounds really familiar! In fact I had almost the exact same issues while I was running carbs. Had to cruise on the highway in 4th, never touch 5th or it goes right over 400*.
Pull off the tins and make sure you don't ave mouse nests blocking your cooling vanes. You can do this with the engine in your car (BTDT) but its a pain. Since your car had carbs its pretty easy to just drop the engine. My issue I figured out after I pulled the carbs and sold them out of frustration. The top gaskets I had bought were defective out of the box. There had been a bad manufacturing run where the top gaskets did not have holes punched for the jets and the engine was always running lean at speed no matter what jetting I put in the mains. It is probably worth rebuilding the carbs and making sure everything is up to snuff. One more thing I will add, the "Factory" AC really ruins the pass side tins. If you have working AC, its probably worth it now that its hot and humid here in the MidA. BUT if yo don't have working AC, pull that crap out and sell it. Get a set of tins that have not been mangled and it will help considerably. Zach |
Superhawk996 |
Jul 6 2020, 08:19 AM
914 Guru Group: Members Posts: 5,876 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
One more thing I will add, the "Factory" AC really ruins the pass side tins. If you have working AC, its probably worth it now that its hot and humid here in the MidA. BUT if yo don't have working AC, pull that crap out and sell it. Get a set of tins that have not been mangled and it will help considerably. Zach If you decide to pull the A/C and cant find 2.0L passenger side tin at a reasonable cost, I can fix your butchered existing 2.0L tin. Did this a few months back for another member. Starting condition Finished repair |
Lo-Fi Version | Time is now: 1st June 2024 - 09:09 PM |
