Stripped exhaust stud on fresh rebuilt heads, Fireworks at my place tonight |
djway |
Jul 5 2020, 01:40 AM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Soooooo
I am installing the exhaust manifolds today, using the nice little copper coated exhaust nuts from Bel Metric and at the point the self locking threads encounter the stud, the stud just starts turning. Little effort to pull it out and the stud is clean, no material in the threads. Now mind you that these heads have just been rebuilt and fixing exhaust studs was on the to do list and the cost was substantial to me. Then the fireworks went off... (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/hissyfit.gif) As the great poet Eric Burdon said in the song PC3 "I rattled so long And rattled so obscene The ground did shake And disturbed the Queen..." This is the motor in my Notchback and it has taken too long to squeeze that puppy in there so this fix is going to be in site. Is it an optical illusion or are the studs at an angle? ie not perpendicular to the ground? I ordered some EZLOCK solid inserts and I will make a drill guide that will bolt onto the other stud. Apologies to the neighbors (IMG:style_emoticons/default/blink.gif) |
914werke |
Jul 11 2020, 09:54 AM
"I got blisters on me fingers" Group: Members Posts: 10,141 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
@djway I have a cut off head exchanger end to use as a drill guide if you need it to drill out to a larger size and use an oversize stud. Sorry to hear that. Bruce Sharp minds think alike (IMG:style_emoticons/default/smile.gif) I used a 1.7L cast flange & drilled it out for the drill guides Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 08:45 AM |
